Chassis question #1176130
02/10/12 06:31 PM
02/10/12 06:31 PM
Peru
cbarracuda Offline OP
Peru
How do you hook a car with a strut front end If the entire travel of the strot is only 3 1/2 inches, and there is only 1.75 inches for the front to come up?
I'm building a full frame for my Cuda and a 4-link and i'm trying to understand what would happened if there is no front end lift and there is only 650 hp on the car.
Re: Chassis question [Re: cbarracuda] #1176131
02/10/12 06:51 PM
02/10/12 06:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually the strut is down father than 1/2 way...
most of the travel is rebound/extension... on my
Strange struts they said 1/2" between the rubber bumper
to the shock housing.... also set the engine back
farther to get better transfer... if you need more
raise the engine up
Re: Chassis question [Re: MR_P_BODY] #1176132
02/10/12 07:24 PM
02/10/12 07:24 PM
Peru
Peru
Good explanation, thank you. I am also going to use strange struts and they have a kit with brakes and bottom A arm, but they say no seal nor bearings on the kit, So I guess they are taking about the inner grease seal and inner-outter bearings, right?
Re: Chassis question [Re: cbarracuda] #1176133
02/10/12 07:32 PM
02/10/12 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My kit came with hubs, brakes, struts and bearings,
and the lower ball joint and arms... everything needed
for the front suspension (lacking the mounting points)
Re: Chassis question [Re: MR_P_BODY] #1176134
02/10/12 08:03 PM
02/10/12 08:03 PM
Peru
Peru
Thatīs the kit I need to get. Iīll call Strange on monday.
Thanks for the info
