Re: NO DASH LIGHTS!!!
[Re: 70RT383]
#1175840
02/10/12 10:03 AM
02/10/12 10:03 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
do you have tail lights too?
or are they out as well?
could indicate where your power problem is if the tail lights are getting power but your dash lights are not, since they're typically on the same fuse/circuit
**Photobucket sucks**
[Re: 70RT383]
#1175843
02/10/12 01:19 PM
02/10/12 01:19 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Okay by dimmeryou mean the one on the floor or the one in the dash? Either way I'd check the other.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1175845
02/11/12 01:10 AM
02/11/12 01:10 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
The headlight switch should have a built in dimmer on it, turn the lightswitch shaft to the right, clockwise, to dim and left, counter clockwise, to brighten the dash lights and turn on the dome light
[Re: 70Cuda383]
#1175848
02/11/12 03:21 PM
02/11/12 03:21 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
in older mopars, they are on the same circuit so you know if your tail lights are not working... - this is the first thing I would check...
