Re: 318 build up
[Re: Beazly464]
#1175746
02/09/12 11:16 PM
02/09/12 11:16 PM
RapidRobert
A cam swap. next would be 302 or mag heads. Once it's running dial in the dist
Re: 318 build up
[Re: Beazly464]
#1175749
02/10/12 09:59 AM
02/10/12 09:59 AM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
I have been thinking of putting my original 318 back into my 68 satellite. How can I get more power out of the engine before I put it back in?
Several ways you can go but, as said it also depends on your budget. On the cheap I would go Summit K6900 cam. Also, the 360 RV cam I hear is a good one don't forget to degree it in. Summit Headers, a good ignition system, a good timing chain, Weiand 8007 intake or Edelbrock Performer topped off by a 800 Thermoquad or 600 Edelbrock or 600 Holley carburetor. Then run a 904 behind it and have a low gearset installed with a decent converter and TF1 or TF2 and it should run alright.
Re: 318 build up
[Re: Mr.Yuck]
#1175751
02/10/12 10:37 AM
02/10/12 10:37 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I would say, good intake, carb, headers, Magnum heads, and a cam in the 220 range for duration.
that combo put my 4,000 lb Dakota into the mid-14s in the 1/4 mile.
**Photobucket sucks**
