318 build up #1175745
02/09/12 11:00 PM
02/09/12 11:00 PM
Frankenmuth, Michigan
Beazly464 Offline OP
I have been thinking of putting my original 318 back into my 68 satellite. How can I get more power out of the engine before I put it back in?
Re: 318 build up [Re: Beazly464] #1175746
02/09/12 11:16 PM
02/09/12 11:16 PM
A cam swap. next would be 302 or mag heads. Once it's running dial in the dist
Re: 318 build up [Re: RapidRobert] #1175747
02/10/12 12:03 AM
02/10/12 12:03 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
small 4 barrel and matching intake.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 318 build up [Re: Beazly464] #1175748
02/10/12 12:48 AM
02/10/12 12:48 AM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
Depending on your budget you can do a complete engine buildup overhaul, My 1974 318 has Keith Black pistons which brings the stroke up to a zero deck, 360 heads shaved down to 63 CC, Edelbrock 650 carb with a dual plane intake. The cam has a wide duration so it's a slightly rough idle but all in all a nice street engine in the Dart sport for under 1000 spent on parts.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: 318 build up [Re: Beazly464] #1175749
02/10/12 09:59 AM
02/10/12 09:59 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Several ways you can go but, as said it also depends on your budget. On the cheap I would go Summit K6900 cam. Also, the 360 RV cam I hear is a good one don't forget to degree it in. Summit Headers, a good ignition system, a good timing chain, Weiand 8007 intake or Edelbrock Performer topped off by a 800 Thermoquad or 600 Edelbrock or 600 Holley carburetor.
Then run a 904 behind it and have a low gearset installed with a decent converter and TF1 or TF2 and it should run alright.
Re: 318 build up [Re: Beazly464] #1175750
02/10/12 10:16 AM
02/10/12 10:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
w/o pulling the heads... Summit t-chian set, Summit cam (smaller), 318 4bbl intake, 500-600cfm carb, Summit headers and 2.5 duals and it'd be a fun ride.
Coming soon!!!!
Re: 318 build up [Re: Mr.Yuck] #1175751
02/10/12 10:37 AM
02/10/12 10:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I would say, good intake, carb, headers, Magnum heads, and a cam in the 220 range for duration.
that combo put my 4,000 lb Dakota into the mid-14s in the 1/4 mile.
**Photobucket sucks**
Re: 318 build up [Re: Beazly464] #1175752
02/10/12 01:13 PM
02/10/12 01:13 PM
cool guys thanks for all the info, I'll have to start researching that stuff out and might start this summer if I have the time and money.
