stock LA rollers lifters . circa 88 #1175586
02/09/12 08:27 PM
02/09/12 08:27 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
what is it with these factory roller lifters?
the truck only has 61k miles..the first time i had to put a lifter in it...had to buy all 16
i put a set of factory lifters in this motor 3 yrs ago.
only put 20k miles..ive got one that went bad again.
it appears to have collapsed..now im wishing i didnt throw out all the old ones...i only need an intake lifter for cyl #6
is there an afordable aftermarket lifter thats better? direct fit..?
now i gotta pull the intake and see whats up..
anyone have any old left over or not using roller lifters for a 88 model 318? I need 2..lol.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: stock LA rollers lifters . circa 88 [Re: cheapstreetdustr] #1175587
02/09/12 11:41 PM
02/09/12 11:41 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I had a similar problem with mine. Stock roller lifters in a 150k shortblock...I cleaned them all, inspected them, put em back together, only to have one collapse...buy a new set of 16 mopar stock replacements, check them all, stick em in, and again one collapses...Not sure what the cause of it is though, since it was different ones that were collapsing
Re: stock LA rollers lifters . circa 88 [Re: cheapstreetdustr] #1175588
02/10/12 02:29 AM
02/10/12 02:29 AM
Delray beach, Florida
P
Performance Only Offline
P
cheapst
we sell singles if you need one. they're a few bucks more when buying them that way but a lot cheaper than buying a full set. i think they're like 11.95 a piece.
machine shop owner and engine builder
Re: stock LA rollers lifters . circa 88 [Re: Performance Only] #1175589
02/10/12 12:31 PM
02/10/12 12:31 PM
the issue i was hoping to achieve with getting a used one is..if it had not failed...it might be a good one..
verses
buying new ones and getting a defective part and continuing this silly game...lol..
sort of thinking..
[image][/image]
Re: stock LA rollers lifters . circa 88 [Re: cheapstreetdustr] #1175590
02/10/12 12:47 PM
02/10/12 12:47 PM
dogdays Offline
dogdays  Offline
There are probably a milion of them out driving around and failures are not common.
R.
Re: stock LA rollers lifters . circa 88 [Re: cheapstreetdustr] #1175591
02/10/12 04:39 PM
02/10/12 04:39 PM
P
P
verses
sort of thinking..
mo problem, you asked if anyone had singles and we do. failures are not common/ i throw away the old ones when we do rebuilds on the magnum motors and we haven't had a single failure that i know of.
i'm sure somebody has to have some old lifters, hopefully they'll see this thread.
