Best Thread Sealer? #1175387
02/09/12 03:05 PM
02/09/12 03:05 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Having a he!! of a time sealing the long water pump bolt that doubles as the power steering adjusting bolt on my fresh 318.
Drained the cooling system, pulled out the bolt, wire-wheeled clean the threads, blasted some brake cleaned in the hole to clean the block threads, let it dry for a few hours. Gooped the bolt threads with some permatex non-hardening sealer, re-installed it. Let it set overnight.
Re-filled in the morning, started it up, and......drip....drip...
This thing is killing me...any suggestions?
Re: Best Thread Sealer? [Re: vdriver] #1175388
02/09/12 03:50 PM
02/09/12 03:50 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I always use either teflon pipe dope or teflon pipe tape. Seals and makes removal, even in aluminum, easy.
Re: Best Thread Sealer? [Re: rbstroker] #1175389
02/09/12 03:53 PM
02/09/12 03:53 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
The "Green Stuff" from Jomar.
Leave the gun.......take the Cannoli's....Mike
Re: Best Thread Sealer? [Re: mike s] #1175390
02/09/12 03:55 PM
02/09/12 03:55 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I use the same orange "hi-heat" RTV I use in the end exhaust manifold/header bolts on the water pump..never had it come back to bite me.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Best Thread Sealer? [Re: vdriver] #1175391
02/09/12 04:24 PM
02/09/12 04:24 PM
Go to your local GM dealer and buy a can of there thread sealer, all the early SB Chevy head bolts went into the water jackets. I use it and it works well
Re: Best Thread Sealer? [Re: Cab_Burge] #1175392
02/09/12 04:44 PM
02/09/12 04:44 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Best Thread Sealer? [Re: vdriver] #1175393
02/09/12 05:31 PM
02/09/12 05:31 PM
Permatex #2 in the toothpaste like tube & grab another identical dimention bolt out of your pile & use it
Re: Best Thread Sealer? [Re: RapidRobert] #1175394
02/09/12 07:44 PM
02/09/12 07:44 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Trying to seal a straight thread such as a bolt thread is a female dog. A straight thread never tightens like a taper thread (pipe) will and thus the problem. For an adjusting bolt that gets turned after installation it becomes even more difficult. For me, the only thing that has ever worked in that type of application is Permatex Super 300.
Re: Best Thread Sealer? [Re: 6PakBee] #1175395
02/09/12 09:52 PM
02/09/12 09:52 PM
dogdays Offline
dogdays  Offline
FelPro Pro Lock Tight is an anaerobic thread sealer/locker that may be hard to find but is also hard to beat.
R.
Re: Best Thread Sealer? [Re: Cab_Burge] #1175396
02/09/12 10:09 PM
02/09/12 10:09 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I was a GM dealer tech for 26 years. Cabs correct this stuff works very well.
Doug
Re: Best Thread Sealer? [Re: dvw] #1175397
02/10/12 12:01 AM
02/10/12 12:01 AM
got a part #
Re: Best Thread Sealer? [Re: RapidRobert] #1175398
02/10/12 12:43 PM
02/10/12 12:43 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Thanks guys for all the suggestions.
Re: Best Thread Sealer? [Re: RapidRobert] #1175399
02/10/12 07:44 PM
02/10/12 07:44 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
got a part #
GM PN# 12346004
