Best Thread Sealer?
#1175387
02/09/12 03:05 PM
02/09/12 03:05 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Having a he!! of a time sealing the long water pump bolt that doubles as the power steering adjusting bolt on my fresh 318. Drained the cooling system, pulled out the bolt, wire-wheeled clean the threads, blasted some brake cleaned in the hole to clean the block threads, let it dry for a few hours. Gooped the bolt threads with some permatex non-hardening sealer, re-installed it. Let it set overnight. Re-filled in the morning, started it up, and......drip....drip... This thing is killing me...any suggestions?
Re: Best Thread Sealer?
[Re: rbstroker]
#1175389
02/09/12 03:53 PM
02/09/12 03:53 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
The "Green Stuff" from Jomar.
Leave the gun.......take the Cannoli's....Mike
[Re: vdriver]
#1175393
02/09/12 05:31 PM
02/09/12 05:31 PM
RapidRobert
Permatex #2 in the toothpaste like tube & grab another identical dimention bolt out of your pile & use it
[Re: Cab_Burge]
#1175396
02/09/12 10:09 PM
02/09/12 10:09 PM
Posts: 9,836 MI, usa
dvw
MI, usa
Go to your local GM dealer and buy a can of there thread sealer, all the early SB Chevy head bolts went into the water jackets. I use it and it works well
I was a GM dealer tech for 26 years. Cabs correct this stuff works very well. Doug
[Re: RapidRobert]
#1175399
02/10/12 07:44 PM
02/10/12 07:44 PM
dvw
MI, usa
got a part #
GM PN# 12346004
