Wiper trick for LX bodies #1174191
02/07/12 08:37 PM
02/07/12 08:37 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I just bought a 2006 Charger R/T. I want to be able to park my wipers halfway up the windshield so I can stuff a piece of cardboard underneath it at night. That way, I don't have to scrape the windshield in the morning. Every other car I've owned, when you turn the key off, the wipers stop wherever they are at. But in the Charger, this trick doesn't work.
Any way to get around this?
Re: Wiper trick for LX bodies [Re: Moparmaniacc] #1174192
02/07/12 09:01 PM
02/07/12 09:01 PM
Massachussetts
RCKTMN Offline
RCKTMN  Offline
Massachussetts
You can simply pull up on the arms and they will stay up off the windshield on their own.
Paul
1970 Barracuda Convertible
1970 Newport Convertible
1970 Satellite Convertible
1974 'Cuda shell - '71 conversion
1988 Oldsmobile Cutlass w/455
2003 RAM3500 CTD
2007 Caliber R/T AWD
2007 Magnum SRT-8
2016 Chrysler Town & Country
Re: Wiper trick for LX bodies [Re: RCKTMN] #1174193
02/07/12 09:33 PM
02/07/12 09:33 PM
Northern Virginia
Northern Virginia
I need the wipers to stop halfway thru their arc, instead of parking in the down position.
Re: Wiper trick for LX bodies [Re: RCKTMN] #1174194
02/07/12 10:00 PM
02/07/12 10:00 PM
33950
67Monaco Offline
67Monaco  Offline
33950
Paul
Not on my LX, the wiper arms hit the hood if they're parked.
Re: Wiper trick for LX bodies [Re: 67Monaco] #1174195
02/07/12 11:37 PM
02/07/12 11:37 PM
Northern Virginia
Northern Virginia
I'm not being clear, let me start over.
I want to stop my wipers halfway through their travel, by turning off the ignition key. With the wipers resting on the windshield as usual. So I can tuck a flat piece of cardboard under the wiper blade, and use the wiper blade to hold it there, instead of blowing away with the wind.
I come out in the morning, I take the cardboard away, and voila! no frost to scrape.
With all the other cars I've owned, I just turn off the ignition key at the right time, and the wiper stays right there.
With this Charger, I can't do that. The wipers always return to the off position, no matter when I pull out the ignition key.
Re: Wiper trick for LX bodies [Re: Moparmaniacc] #1174196
02/07/12 11:58 PM
02/07/12 11:58 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Re: Wiper trick for LX bodies [Re: Moparmaniacc] #1174197
02/08/12 12:04 AM
02/08/12 12:04 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Try having your door open when you turn the key off. Not sure if it will work or not but worth a try
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: Wiper trick for LX bodies [Re: sreinheimer] #1174198
02/08/12 05:26 PM
02/08/12 05:26 PM
Massachussetts
RCKTMN Offline
RCKTMN  Offline
Massachussetts
My bad. I thought you were trying to keep the blade off the windshield so that it wouldn't freeze on. I understand what you want now. As posted above, you could try opening the door after you turn the key to off and the wipers are mid-travel. It may shut power to them as it does to the radio.
Good luck!
Paul
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: Wiper trick for LX bodies [Re: RCKTMN] #1174199
02/08/12 06:06 PM
02/08/12 06:06 PM
Andrewh Offline
Andrewh  Offline
have you tried turning off the car and pulling the key out?
not just turning it off.
I agree, you can also try opening the door too.
Re: Wiper trick for LX bodies [Re: Moparmaniacc] #1174200
02/08/12 06:44 PM
02/08/12 06:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There might be a programable mode that keeps the accessory power on after the key is turned off, check your owners manual for instructions to shut it off.
