could someone decode my 440 #1172801
02/05/12 09:21 PM
02/05/12 09:21 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
We bought a truck this weekend with a transplanted 440.It reads 7 T 440 E 2 2 2 maltease cross diamond.I know the e is cast crank not sure about the rest.
Re: could someone decode my 440 [Re: chargers777] #1172802
02/06/12 03:03 AM
02/06/12 03:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
7 = 1977 model year
T = Trenton engine plant
440 = 440
2 2 2 = assembled Feb 2nd 1977 on the 2nd shift
Maltese cross means the crank is .001 undersize.
THE KILLER , Diamond means the lifter bores are .008 OVERSIZE , unless you have the lifter bores BUSHED the block is JUNK, NO ONE sells .008 oversize lifters .. not even Chrysler anymore...
Been there , bushed the block after 2 failed cams ...
Re: could someone decode my 440 [Re: JohnRR] #1172803
02/06/12 04:34 AM
02/06/12 04:34 AM
Nashport, OH
Nashport, OH
The motor runs great so I dont plan on tearing it down.Thanks for the info.Is that one bearing is undersize and one lifter bore or all of them?
Re: could someone decode my 440 [Re: JohnRR] #1172804
02/06/12 06:51 AM
02/06/12 06:51 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
7 = 1977 model year
2 2 2 = assembled Feb 2nd 1972 on the 2nd shift
Sorry John, but, not to be a critic, that motor most likely wasn't built/assembled 5 years prior to 77.
Re: could someone decode my 440 [Re: Dean_Kuzluzski] #1172805
02/06/12 09:14 AM
02/06/12 09:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Typo on my part obviously , thanks for pointing it out .
Re: could someone decode my 440 [Re: chargers777] #1172806
02/06/12 09:16 AM
02/06/12 09:16 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No that is ALL the mains and I think rods because it doesn't specify which.
ALL lifter bores, but even if it were one lifter bore you still have to bush the block because no one makes that lifter size.
As long as you are happy with it in it's current configuration you are all set.
Re: could someone decode my 440 [Re: JohnRR] #1172807
02/06/12 01:45 PM
02/06/12 01:45 PM
dogdays Offline
dogdays  Offline
Just don't lose those OS lifters!
R.
Re: could someone decode my 440 [Re: dogdays] #1172808
02/06/12 01:50 PM
02/06/12 01:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
I guess if he wanted to he could attempt to rebuild them and send them out to be refaced to use on another cam .
Re: could someone decode my 440 [Re: JohnRR] #1172809
02/06/12 02:38 PM
02/06/12 02:38 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
so its a 72?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: could someone decode my 440 [Re: 440lebaron] #1172810
02/06/12 03:13 PM
02/06/12 03:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
so its a 72?
I screwed up , I had 2 2 2 on my brain , it's a 77 .
Re: could someone decode my 440 [Re: JohnRR] #1172811
02/06/12 03:24 PM
02/06/12 03:24 PM
dogdays Offline
dogdays  Offline
Or could have new lifters plated to oversize.
I remember a Mopar Muscle article about a 340 block that had this problem, gave the builder fits.
R.
Re: could someone decode my 440 [Re: dogdays] #1172812
02/06/12 03:55 PM
02/06/12 03:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
I had a block was not stamped oversize but the bores were out of whack and the geometry was way out , best and easiest way to correct was to bush the block .
Re: could someone decode my 440 [Re: JohnRR] #1172813
02/06/12 05:15 PM
02/06/12 05:15 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
R.
What's the cost for that? I would have thought that unless it was a #'s block, it would be cheaper to start with a block that doesn't have any issues? Just curious.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: could someone decode my 440 [Re: DPelletier] #1172814
02/06/12 06:19 PM
02/06/12 06:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
I had no choice , it had a ton of other machine work already done, was lucky it only cost $750 considering where it was when it was found.
Just had it done to my current pure stock build 383 , cost about $500 , the plus is it caps off the free flow of oil past the lifters , more oil goes where it's supposed to go instead of just flooding the rotating assembly .
Re: could someone decode my 440 [Re: JohnRR] #1172815
02/06/12 06:26 PM
02/06/12 06:26 PM
DPelletier Offline
DPelletier  Offline
Hmm; I see....so probably best to pass on the block if you know it has this marking up front then.
The 383 is for the Dart, right? you've been talking about getting that car to the PSMCDR for almost as many years as I have! Maybe we'll both get there in the next year or two!
Re: could someone decode my 440 [Re: DPelletier] #1172816
02/06/12 06:57 PM
02/06/12 06:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes if the block has a diamond stamped on the pad pass unless it comes with an envelope full of 20's .
the 383 is for the dart ,the plan is to be there this year , I'm done doing things for others , working on my own stuff now .
Re: could someone decode my 440 [Re: JohnRR] #1172817
02/07/12 12:24 PM
02/07/12 12:24 PM
DPelletier Offline
DPelletier  Offline
Yes if the block has a diamond stamped on the pad pass unless it comes wit han envolpe full of 20's .
Well good luck! My car SHOULD be done this spring, but I'm not sure I'll be able to drag it all the way to Michigan this fall......might fly out and watch the fun though.
Re: could someone decode my 440 [Re: chargers777] #1172818
02/07/12 12:33 PM
02/07/12 12:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I thought GG was gonna do all the decoding now on Moparts? Isn't that what he does? Come on GG a little help would be in order IMO.
Re: could someone decode my 440 [Re: Challenger 1] #1172819
02/07/12 01:38 PM
02/07/12 01:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
