Re: could someone decode my 440
[Re: Dean_Kuzluzski]
#1172805
02/06/12 09:14 AM
02/06/12 09:14 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Sorry John, but, not to be a critic, that motor most likely wasn't built/assembled 5 years prior to 77.
Typo on my part obviously , thanks for pointing it out .
[Re: chargers777]
#1172806
02/06/12 09:16 AM
02/06/12 09:16 AM
JohnRR
U.S.S.A.
The motor runs great so I dont plan on tearing it down.Thanks for the info.Is that one bearing is undersize and one lifter bore or all of them?
No that is ALL the mains and I think rods because it doesn't specify which.
ALL lifter bores, but even if it were one lifter bore you still have to bush the block because no one makes that lifter size.
As long as you are happy with it in it's current configuration you are all set.
[Re: dogdays]
#1172808
02/06/12 01:50 PM
02/06/12 01:50 PM
JohnRR
U.S.S.A.
Just don't lose those OS lifters!
R.
I guess if he wanted to he could attempt to rebuild them and send them out to be refaced to use on another cam .
[Re: 440lebaron]
#1172810
02/06/12 03:13 PM
02/06/12 03:13 PM
JohnRR
U.S.S.A.
so its a 72?
I screwed up , I had 2 2 2 on my brain , it's a 77 .
[Re: dogdays]
#1172812
02/06/12 03:55 PM
02/06/12 03:55 PM
JohnRR
U.S.S.A.
Or could have new lifters plated to oversize. I remember a Mopar Muscle article about a 340 block that had this problem, gave the builder fits.
R.
I had a block was not stamped oversize but the bores were out of whack and the geometry was way out , best and easiest way to correct was to bush the block .
[Re: JohnRR]
#1172813
02/06/12 05:15 PM
02/06/12 05:15 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
R.
What's the cost for that? I would have thought that unless it was a #'s block, it would be cheaper to start with a block that doesn't have any issues? Just curious.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1172814
02/06/12 06:19 PM
02/06/12 06:19 PM
JohnRR
U.S.S.A.
R.
I had no choice , it had a ton of other machine work already done, was lucky it only cost $750 considering where it was when it was found.
Just had it done to my current pure stock build 383 , cost about $500 , the plus is it caps off the free flow of oil past the lifters , more oil goes where it's supposed to go instead of just flooding the rotating assembly .
[Re: JohnRR]
#1172815
02/06/12 06:26 PM
02/06/12 06:26 PM
DPelletier
Hmm; I see....so probably best to pass on the block if you know it has this marking up front then.
The 383 is for the Dart, right? you've been talking about getting that car to the PSMCDR for almost as many years as I have! Maybe we'll both get there in the next year or two!
1974 'Cuda
[Re: DPelletier]
#1172816
02/06/12 06:57 PM
02/06/12 06:57 PM
JohnRR
U.S.S.A.
Yes if the block has a diamond stamped on the pad pass unless it comes with an envelope full of 20's .
the 383 is for the dart ,the plan is to be there this year , I'm done doing things for others , working on my own stuff now .
[Re: Challenger 1]
#1172819
02/07/12 01:38 PM
02/07/12 01:38 PM
JohnRR
U.S.S.A.
I thought GG was gonna do all the decoding now on Moparts? Isn't that what he does? Come on GG a little help would be in order IMO.
