Re: Ballist resistor overheating
[Re: cudarroger]
#1172729
02/05/12 08:18 PM
02/05/12 08:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I am lost on this one. 70 aar factory 340 dual points. The car will start and idle fine and the ballist resistor heats up and the ignition starts breaking up and the car dies and burns out the condenser. Is there back feed from somewhere? All suggestions are appreciated.
There are different Ohm rated 2 prong ballast resistors avaliable for Chysler/AMC
Have you confirmed the wiring on the coil, Blue wire off the bulhead (ignition) is positive (+), the distributor/point(s) Black, is (-) negitive on the coil, a 2 prong ballast has no terminal specification
[Re: cudarroger]
#1172730
02/05/12 08:18 PM
02/05/12 08:18 PM
RapidRobert
I could see w the ign left "on" that current could burn out the ballast but I'd sure think it'd burn the points first tho w both sets closed they would be passing 1/2 the amount I'd think (parallel circuit). Lets solve the breaking up that's making it die. More info/details please. Correct ohm ballast I'm assuming
[Re: cudarroger]
#1172732
02/06/12 12:43 AM
02/06/12 12:43 AM
RapidRobert
1.25 ohm ballast w the orange/chrome box. .25 ohm w the gold box. Those are nominal ratings, actual vary widely & OE 2 terminal ballast vary widely also. We're missing something here
[Re: cudarroger]
#1172733
02/06/12 01:07 AM
02/06/12 01:07 AM
Posts: 512 Niwot, CO Formerly denn...
dynorad
Need to know coil resistance as well. The current in the primary ignition circuit is determined by the sum of the ballast and coil resistances. Also need to ensure that you don't have an overcharging condition so your voltage is too high thus burning things up.
[Re: cudarroger]
#1172734
02/06/12 03:33 AM
02/06/12 03:33 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I did not know that there are to different ohm resistance. What are the two different ratings?
Would be great if you "spill the beans" on what parts your running, any mods you've performed, etc, etc, rather than assume you have factory parts or the proper aftermarket parts
[Re: cudarroger]
#1172735
02/06/12 04:07 AM
02/06/12 04:07 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
How is the condenser burnt out? Is it shorting out? That would make the ballast run hot.
[Re: dynorad]
#1172738
02/07/12 11:01 PM
02/07/12 11:01 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
I have had condensers fail from the new clamp crushing it. As a rule, I always reuse the old clamp on new condensers to avoid this. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
