Ballist resistor overheating #1172728
02/05/12 06:51 PM
02/05/12 06:51 PM
Home of the Dart
cudarroger Offline OP
Home of the Dart
I am lost on this one. 70 aar factory 340 dual points. The car will start and idle fine and the ballist resistor heats up and the ignition starts breaking up and the car dies and burns out the condenser. Is there back feed from somewhere? All suggestions are appreciated.
Re: Ballist resistor overheating [Re: cudarroger] #1172729
02/05/12 08:18 PM
02/05/12 08:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There are different Ohm rated 2 prong ballast resistors avaliable for Chysler/AMC
Have you confirmed the wiring on the coil, Blue wire off the bulhead (ignition) is positive (+), the distributor/point(s) Black, is (-) negitive on the coil, a 2 prong ballast has no terminal specification
Re: Ballist resistor overheating [Re: cudarroger] #1172730
02/05/12 08:18 PM
02/05/12 08:18 PM
I could see w the ign left "on" that current could burn out the ballast but I'd sure think it'd burn the points first tho w both sets closed they would be passing 1/2 the amount I'd think (parallel circuit). Lets solve the breaking up that's making it die. More info/details please. Correct ohm ballast I'm assuming
Re: Ballist resistor overheating [Re: RapidRobert] #1172731
02/06/12 12:39 AM
02/06/12 12:39 AM
Home of the Dart
Home of the Dart
I did not know that there are to different ohm resistance. What are the two different ratings?
Re: Ballist resistor overheating [Re: cudarroger] #1172732
02/06/12 12:43 AM
02/06/12 12:43 AM
1.25 ohm ballast w the orange/chrome box. .25 ohm w the gold box. Those are nominal ratings, actual vary widely & OE 2 terminal ballast vary widely also. We're missing something here
Re: Ballist resistor overheating [Re: cudarroger] #1172733
02/06/12 01:07 AM
02/06/12 01:07 AM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Need to know coil resistance as well. The current in the primary ignition circuit is determined by the sum of the ballast and coil resistances.
Also need to ensure that you don't have an overcharging condition so your voltage is too high thus burning things up.
Re: Ballist resistor overheating [Re: cudarroger] #1172734
02/06/12 03:33 AM
02/06/12 03:33 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Would be great if you "spill the beans" on what parts your running, any mods you've performed, etc, etc, rather than assume you have factory parts or the proper aftermarket parts
Re: Ballist resistor overheating [Re: cudarroger] #1172735
02/06/12 04:07 AM
02/06/12 04:07 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
How is the condenser burnt out? Is it shorting out? That would make the ballast run hot.
Re: Ballist resistor overheating [Re: 451Mopar] #1172736
02/06/12 11:27 AM
02/06/12 11:27 AM
Home of the Dart
Home of the Dart
I'm running all stock componets. Coil, ballast, V.R., Factory distributer,dual points and condenser, Plumcrazy Garage restored alternator. Was there ever a ground strap on an E-body from the engine to the firewall? I don't remember one being there. How would the condenser be shorting out?
Re: Ballist resistor overheating [Re: cudarroger] #1172737
02/07/12 06:38 PM
02/07/12 06:38 PM
dynorad Offline
dynorad  Offline
Have you shorted out more than one condenser? The condenser is a big capacitor. It does not have DC current passing through it unless it is shorted. Unless it shorted out from old age the only way to short them is to have too much voltage across it, as far as I know.
Re: Ballist resistor overheating [Re: dynorad] #1172738
02/07/12 11:01 PM
02/07/12 11:01 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I have had condensers fail from the new clamp crushing it. As a rule, I always reuse the old clamp on new condensers to avoid this.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
