Which fastener?? See pic #1172708
02/05/12 05:09 PM
02/05/12 05:09 PM
alberta
Publicbottle Offline OP
alberta
Hey all,
Workin on my 70 challenger, and just referring to the bracket that goes from the k-frame to the lower rad support. i cant seem to find which fasnter is correct for the rad side of the bracket. Can anyone help??
Thanks!!
Re: Which fastener?? See pic [Re: Publicbottle] #1172709
02/05/12 06:23 PM
02/05/12 06:23 PM
I think it uses one of those thin tinnerman? nuts like are used on some fender fastening points. Thin U shaped nut that you push onto the edge then the bolt goes thru all of it
Re: Which fastener?? See pic [Re: RapidRobert] #1172710
02/05/12 06:44 PM
02/05/12 06:44 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1/4-20 Bolts with a J type nut
Re: Which fastener?? See pic [Re: gtx6970] #1172711
02/06/12 01:16 AM
02/06/12 01:16 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Both sets of bolts are off a 71 charger.The upper
ones are on the core support and the lowers are on the k-frame.My 70 cuda used the same bolts.The lower bolt has part of the head ground off from hitting curbs
NS1AAR
Re: Which fastener?? See pic [Re: ns1aar] #1172712
02/06/12 01:17 AM
02/06/12 01:17 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like mine..
