Re: Which fastener?? See pic
[Re: Publicbottle]
#1172709
02/05/12 06:23 PM
02/05/12 06:23 PM
RapidRobert
I think it uses one of those thin tinnerman? nuts like are used on some fender fastening points. Thin U shaped nut that you push onto the edge then the bolt goes thru all of it
[Re: gtx6970]
#1172711
02/06/12 01:16 AM
02/06/12 01:16 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Both sets of bolts are off a 71 charger.The upper ones are on the core support and the lowers are on the k-frame.My 70 cuda used the same bolts.The lower bolt has part of the head ground off from hitting curbs
NS1AAR
