Re: 6 spd swap progress
[Re: dezduster]
#1172682
04/08/12 10:50 PM
04/08/12 10:50 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Im sticking with a 3.91 with the 6spd. First gear in the T56 is same A833 and ive been in plenty of cars with that combo and it flat rips. In 6th gear im a hair over 2000rpm at 80 rpm which is where I want to be on the interstate. Thanks for the advise. If I had a 5 speed id run 3.55s.
Mopar to the bone!!!
[Re: 72Swinger]
#1172685
04/16/12 02:48 AM
04/16/12 02:48 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Was admiring your work and saw the windage tray while you were putting the pan on your engine. I looked through the jegs website and they have two windage trays available with rubber gaskets built in. One for 3.75 stroke and the other for 4.15. I know they aren't that hard to seal up, but I thought I'd throw that out there while you're at that point. Here's a link to the part: http://www.jegs.com/i/JEGS+Performance+Products/555/502000/10002/-1
[Re: dodgeboy11]
#1172686
04/16/12 12:30 PM
04/16/12 12:30 PM
72Swinger
Nebraska
Yes I have seen those and they are a great deal. Im just going to use what I have but thanks for the heads up! Gonna clean up the firewall and situate some wiring today so as soon as my pushrods arrive I can start putting this old [Edited by Moparts - Family Friendly Site - Keep it clean] back together.
[Re: 72Swinger]
#1172687
04/21/12 08:11 PM
04/21/12 08:11 PM
72Swinger
Nebraska
Finally going in the right direction.....back together!
[Re: 72Swinger]
#1172688
04/21/12 08:13 PM
04/21/12 08:13 PM
72Swinger
Nebraska
Trans in its final resting place.....
[Re: 72Swinger]
#1172689
04/21/12 08:14 PM
04/21/12 08:14 PM
72Swinger
Nebraska
Interior be will nice and fresh as well...
[Re: Keith Black®]
#1172691
04/24/12 10:53 AM
04/24/12 10:53 AM
72Swinger
Nebraska
Wow, love how you did the mount! Did you replace your whole tunnel?
[Re: jcc]
#1172693
04/24/12 11:26 AM
04/24/12 11:26 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If that was mine, If I am seeing everything correctly, I'd add 2 mirror image gussets as space allows for expected exhaust pipe clearances, on either side of those slightly off vertical flat bar pieces connecting to the rectangular horizontal tubes. The current connection is a stress concentration point, and likely to have little rigidity because at that connection point the cross sectional area is suddenly greatly reduced. How much loading on this member is unknown, but the weakness remains.
Absolutely..
[Re: jcc]
#1172694
04/24/12 11:52 AM
04/24/12 11:52 AM
72Swinger
Nebraska
Doing that would definitely make it stronger. What you dont see,or maybe you can,is there is 1/8" plate stacked on each other on both sides, but spread apart about 3/8" at the tops where in ties into the cross pieces. My attaching bolt arrangement also helps the crossmember from being springy. If I could've afforded a Magnum T56 like Darren used I could've used the factory crossmember location and worked from there but this seemed the lesser of 2 evils with a Viper trans.
[Re: Keith Black®]
#1172696
05/13/12 03:57 PM
05/13/12 03:57 PM
72Swinger
Nebraska
Latest developments... 67 B body housing
[Re: 72Swinger]
#1172697
05/13/12 03:59 PM
05/13/12 03:59 PM
72Swinger
Nebraska
742 case 3.91s and Power Lok
[Re: 72Swinger]
#1172698
05/13/12 04:00 PM
05/13/12 04:00 PM
72Swinger
Nebraska
Engine bay getting closer. Gonna use a breather tank plumbed into the valley pan.
[Re: 72Swinger]
#1172700
05/13/12 04:02 PM
05/13/12 04:02 PM
72Swinger
Nebraska
Backseat turned out nice!
