Factory guages read low. #117186
09/08/08 09:58 AM
09/08/08 09:58 AM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline OP
My oil pressure reads 40 PSI on the factory guage but reads 70 PSI on my Autometer mechanical guage. Temp reads low on factory guage and 185º on my Autometer mechanical guage. I also think the fuel guage reads low. What can I do to correct the factory guages. Would it be the voltage limiter? Where can I get a solid state unit? This is on my 1978 Ramcharger.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Factory guages read low. [Re: Blown_Hemi] #117187
09/08/08 10:00 AM
09/08/08 10:00 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I would start with trying a limiter. Also make sure the ground is good. Some had a seperate wire that grounded on one of the dimmer switch screws.
Re: Factory guages read low. [Re: NITROUSN] #117188
09/08/08 12:50 PM
09/08/08 12:50 PM
The ground is good, a lead goes directly to the firewall. I will try a different limiter. Who converts these or sells solidstate ones?
Re: Factory guages read low. [Re: Blown_Hemi] #117189
09/08/08 01:14 PM
09/08/08 01:14 PM
places
79powerwagon Offline
places
Truck grounds suck, period. So do the factory gauges.
I always run a separate grounding harness for everything straight to the negative terminal of the battery. It's a pain, but it works!
Also, the factory gauges were never intended to be accurate, they were there really to show that a system was functioning.
