67 318 & 68 904 transmission. #1171616
02/04/12 10:33 AM
02/04/12 10:33 AM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
Hey guys just wondering if newer trans will bolt up to the 67 318? Thank you and yes the. 67 is an LA.
Re: 67 318 & 68 904 transmission. [Re: OrangeProwler] #1171617
02/04/12 02:52 PM
02/04/12 02:52 PM
Any SB Mopar trans (from 1964 LA motor on to end of production) will bolt up to any SB Mopar engine
Re: 67 318 & 68 904 transmission. [Re: OrangeProwler] #1171618
02/04/12 03:45 PM
02/04/12 03:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Torque converter pilot may be incorrect.
Re: 67 318 & 68 904 transmission. [Re: buildanother] #1171619
02/04/12 04:40 PM
02/04/12 04:40 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
you may be correct . i believe the 67n tranny had the pump at the rear and you could push start it if the battery was dead . now the 68 was changed and i believe the pump drive was different and like said above the converter pilot is different . take the 68 converter and try mating it to the crank and see if it fits , u may have to have one of them machined .
Re: 67 318 & 68 904 transmission. [Re: mopar_man] #1171620
02/04/12 04:48 PM
02/04/12 04:48 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
No, they got rid of the rear pump in 66 (the 727 that is)
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: 67 318 & 68 904 transmission. [Re: OrangeProwler] #1171621
02/04/12 05:28 PM
02/04/12 05:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'68 is the changeover year for the 904, the '67 has a smaller input shaft and converter pilot hub.
Re: 67 318 & 68 904 transmission. [Re: John_Kunkel] #1171622
02/04/12 06:49 PM
02/04/12 06:49 PM
so the 68 TC (& therefor the 68 trans) with the larger nub will not fit the 67 LA cranks' smaller recess correct?
Re: 67 318 & 68 904 transmission. [Re: RapidRobert] #1171623
02/05/12 10:06 PM
02/05/12 10:06 PM
Middle of A Field
O
O
Middle of A Field
Found out the 67 318 came with a 727 so the converter will work. The only potential grey area will be the flexplate.
Re: 67 318 & 68 904 transmission. [Re: OrangeProwler] #1171624
02/06/12 03:09 AM
02/06/12 03:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What gray area , the flexplate only has to bolt to the converter , nothing is different.
Re: 67 318 & 68 904 transmission. [Re: JohnRR] #1171625
02/06/12 07:34 AM
02/06/12 07:34 AM
Middle of A Field
O
O
Middle of A Field
John,
Hello, I am wondering myself but, I found this on another site when I asked.
"The only gray area is going to be the flex plate. The '67 318 engine would have only had a 727 behind it and there could have been two different flex plate options....a large converter bolt pattern and a small pattern. The 904 would have the small pattern. Worst scenario is you have to swap to the small V8 flex plate."
I did confirm the car did have a 727 in it. I was under the impression that in 67 you could get a 904 behind a 318 LA engine (not poly) but, looks like it is not the case? Anyways, I figure I would ask.
Re: 67 318 & 68 904 transmission. [Re: buildanother] #1171626
02/06/12 07:36 AM
02/06/12 07:36 AM
Middle of A Field
O
O
Middle of A Field
That was my concern but, considering the car came with a 727 it may not be an issue. We have an aftermarket converter in the car so...
Re: 67 318 & 68 904 transmission. [Re: OrangeProwler] #1171627
02/06/12 09:46 AM
02/06/12 09:46 AM
chicagoland,usa
chicagoland,usa
I would make certain of the pilot diameter, verses the crank cavity diam, for sure before stuffing it together.
Re: 67 318 & 68 904 transmission. [Re: buildanother] #1171628
02/06/12 06:29 PM
02/06/12 06:29 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Having a too-small snout in a too-big hole is asking for trouble.
Re: 67 318 & 68 904 transmission. [Re: Fury Fan] #1171629
02/06/12 07:43 PM
02/06/12 07:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it's been verified that the motor was mated to a 727 there won't be a problem, the 727 never used the small converter pilot hub.
Re: 67 318 & 68 904 transmission. [Re: John_Kunkel] #1171630
02/09/12 08:58 PM
02/09/12 08:58 PM
Middle of A Field
O
O
Middle of A Field
Thank you.
