Re: 67 318 & 68 904 transmission.
[Re: mopar_man]
#1171620
02/04/12 04:48 PM
02/04/12 04:48 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
you may be correct . i believe the 67n tranny had the pump at the rear and you could push start it if the battery was dead . now the 68 was changed and i believe the pump drive was different and like said above the converter pilot is different . take the 68 converter and try mating it to the crank and see if it fits , u may have to have one of them machined .
No, they got rid of the rear pump in 66 (the 727 that is)
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: OrangeProwler]
#1171621
02/04/12 05:28 PM
02/04/12 05:28 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'68 is the changeover year for the 904, the '67 has a smaller input shaft and converter pilot hub.
[Re: John_Kunkel]
#1171622
02/04/12 06:49 PM
02/04/12 06:49 PM
RapidRobert
so the 68 TC (& therefor the 68 trans) with the larger nub will not fit the 67 LA cranks' smaller recess correct?
[Re: OrangeProwler]
#1171624
02/06/12 03:09 AM
02/06/12 03:09 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Found out the 67 318 came with a 727 so the converter will work. The only potential grey area will be the flexplate.
What gray area , the flexplate only has to bolt to the converter , nothing is different.
[Re: buildanother]
#1171626
02/06/12 07:36 AM
02/06/12 07:36 AM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Torque converter pilot may be incorrect.
That was my concern but, considering the car came with a 727 it may not be an issue. We have an aftermarket converter in the car so...
[Re: buildanother]
#1171628
02/06/12 06:29 PM
02/06/12 06:29 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I would make certain of the pilot diameter, verses the crank cavity diam, for sure before stuffing it together.
Having a too-small snout in a too-big hole is asking for trouble.
[Re: Fury Fan]
#1171629
02/06/12 07:43 PM
02/06/12 07:43 PM
John_Kunkel
Rio Linda, CA
If it's been verified that the motor was mated to a 727 there won't be a problem, the 727 never used the small converter pilot hub.
