Powder coating chassis? #1171593
02/04/12 06:50 AM
02/04/12 06:50 AM
Finland
mafo Offline OP
mafo  Offline OP
Finland
Anyone knows what can be used as a filler before powder coating?
If I understand correctly they will heat it to almost 400*F , would lead work or is there something better?
I m new to this but I bet some of you knows
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Powder coating chassis? [Re: mafo] #1171594
02/04/12 11:05 AM
02/04/12 11:05 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u have to use a metal filler. eastwood has good stuff, that's what i use. seeya.
Re: Powder coating chassis? [Re: rickraw] #1171595
02/04/12 01:03 PM
02/04/12 01:03 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
You may want to build a jig for it also...as the heat can cause the weld stress's to pull and or push on intersections that cause the frame to distort after being heat sinked from the bake in a powedercoating process?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Powder coating chassis? [Re: cheapstreetdustr] #1171596
02/04/12 02:10 PM
02/04/12 02:10 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
We use JB Weld at our shop.
May be hard to get it really smooth over tin work.
Re: Powder coating chassis? [Re: cheapstreetdustr] #1171597
02/04/12 05:29 PM
02/04/12 05:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmmm ... so the heat won't affect the jig ?!?!?!?
Actually the bake process doesn't heat the base metal anywhere near the powder "melt" temp, it basically only has to melt the powder. When the item comes out of the oven it can be handled with bare hands within about ten minutes - try doing that with something that was brought up to the full 400+ degrees!
Re: Powder coating chassis? [Re: Stanton] #1171598
02/04/12 05:47 PM
02/04/12 05:47 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
depending on the size of the part, some will see 400 deg. i have shot some parts i coated with a infrared heat gun & saw 400 deg. then again, that took half the bake time which is 30 min. seeya. never seen any big company use a jig on a car frame. seeya.
Re: Powder coating chassis? [Re: rickraw] #1171599
02/05/12 06:44 AM
02/05/12 06:44 AM
Finland
mafo Offline OP
mafo  Offline OP
Finland
Ok, thanks guys
I guess we have to check what products are available here and maybe test
a few to see how they work
Re: Powder coating chassis? [Re: mafo] #1171600
02/05/12 11:49 AM
02/05/12 11:49 AM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Not sure what color you're using, a couple coats of a textured color is a little more forgiving at hiding imperfections on your material IMO. Use a clear coat on top if you want it shiny/glossy and smooth.
Re: Powder coating chassis? [Re: mafo] #1171601
02/05/12 03:04 PM
02/05/12 03:04 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
As a wood and metal refinisher for over 20 yrs. polyester is not the ideal finish for a chassis.Other than having it coated in a place (like AZ) where the humidity is low 5-15% you always trap moisture under the coating. Polyester ia also very sensitive to unclean sufaces. Having stripped many metal surfaces coated with polyester, very few items are ever rust free when the coating has been removed. Using an epoxy primer with either a single or 2 stage topcoat protects the surface from the elements, is easy to touch up, easier to remove when needing to reweld a spot and will not hide rust and any structural problems with a chassis. Plus you can do it in your shop and save $.
Re: Powder coating chassis? [Re: A/MP] #1171602
02/05/12 04:20 PM
02/05/12 04:20 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I am no Xpert ... but I don't think PCing is "legal" on a chassis that might need-to-be certed.
Re: Powder coating chassis? [Re: dOoC] #1171603
02/05/12 06:47 PM
02/05/12 06:47 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
NHRA general regulations mention "plating" of a chassis, but I am not sure about powder coating.
4:11 ROLL CAGE
All cage structures must be designed in an attempt to protect the driver from any angle, 360 degrees. All 4130 chromoly tube welding must be done by approved TIG heliarc process; mild steel tube welding must be approved MIG wire feed or TIG heliarc process. Welding must be free of slag and porosity. Any grinding of welds prohibited. Plating of chassis prohibited for all cars manufactured after Jan. 1, 2003, unless otherwise noted in Class Requirements; painting permitted.
Re: Powder coating chassis? [Re: ProStDodge] #1171604
02/05/12 08:16 PM
02/05/12 08:16 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
4:11 ROLL CAGE
yeah I know no chrome plating is allowed but I have seen a lot of powder coated ones.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Powder coating chassis? [Re: dusturbd340W5] #1171605
02/05/12 08:25 PM
02/05/12 08:25 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
PCing is way thicker(and "hides" A LOT more) than any chrome-plating process I have ever seen ....
Re: Powder coating chassis? [Re: dusturbd340W5] #1171606
02/05/12 08:27 PM
02/05/12 08:27 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
If this is a race chassis, powder coating is not a good idea at all, any crack in a weld will be extremely hard to see and harder to repair.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Powder coating chassis? [Re: 23T Hemmee] #1171607
02/05/12 09:00 PM
02/05/12 09:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
besides that, it's really hard to remove.
Re: Powder coating chassis? [Re: rickraw] #1171608
02/05/12 11:23 PM
02/05/12 11:23 PM
As i understand it chrome plating a chassis...
if you get a scratch in the chrome it could cause it to create a stress risor crack in the chromolly? similar to the phenomenon in glass
as to the jig..and powder coating...we saw this happen...My chassis guy built Panoz race car chassis for a while and they had issues with fitment of parts after powder coating..
things like radiator mounting brackets and even
suspension support members..and light or small tube brackets that where body supports..
often they would be way off..when it came time to mount the hardware..
he had to make temporary jig bars to keep these parts from moving during powder coating ..
fwiw.
long tubes with lots of little welded do-dads seem to move the most...
[image][/image]
Re: Powder coating chassis? [Re: cheapstreetdustr] #1171609
02/06/12 03:09 PM
02/06/12 03:09 PM
dogdays Offline
dogdays  Offline
The "flaw in the chrome" thing is mostly for hard chromed things like rod journals.
The reason you don't chrome chassis or suspension parts is HYDROGEN EMBRITTLEMENT. Look it up.
R.
Re: Powder coating chassis? [Re: dogdays] #1171610
02/10/12 01:38 PM
02/10/12 01:38 PM
md
W
wicked Offline
wicked  Offline
W
md
A product called Lab Metal for moulding before powdercoat. Welding can introduce tension into the structure and so can fit up, tubing has already been welded along it's length. cycle frames have been known to relax from the pc baking process and walk(though typically smaller dia tube). Like stated above the longer the unsupported run the higher the chances.
It all depends how much tension is already there, but I have definitely seen where the baking process is enough heat to tweak stuff if the structure hasn't been "normalized" after welding.
Hydrogen embrittlement pretty serious , I cringe when I see plated suspension components.
