6.535 rods with chrysler journals?
#1170321
02/01/12 10:49 PM
02/01/12 10:49 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
any source for steel rods like these? Need a 6.535 rod, with standard 2.5/2.375 big end bore and .990 pin... I have not found any yet?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: 6.535 rods with chrysler journals?
[Re: Bob_Coomer]
#1170324
02/02/12 01:07 PM
02/02/12 01:07 PM
Posts: 10,008 Frostbitefalls MN (Rocky&Bullw...
gregsdart
BME made aluminum rods for Indy Cyl Heads with those exact dimensions. Had a set in a 499 build years ago. BME will make them I am sure, might be able to scrounge a set still on a shelf. I know you asked for steel, but I don't remember anyone making them?
[Re: AAR-B4]
#1170326
02/02/12 11:05 PM
02/02/12 11:05 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
Greg
INDY supplied a BME 6.570 rod with MOPAR journals for my 528" low deck. I never saw a 6.535 with MOPAR journals in the INDY catalog..
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: AAR-B4]
#1170327
02/02/12 11:44 PM
02/02/12 11:44 PM
Posts: 976 ontario canada
mac56
ontario canada
There must be a good answer to this............. Why not grind the crank to 2.200?
That is what I just had done to run a chev 6.535 rod.
[Re: AAR-B4]
#1170328
02/02/12 11:48 PM
02/02/12 11:48 PM
Bob_Coomer
Rock Springs
It's cheaper to buy new rods than grind the crank... I have thought about it.. work on the crank alone would probably be expensive... grinding and retreating...then rebalancing, then your still buying new rods. the loss in mass from journal size is negligible in this engine... Worth zero power, but I guess makes it fit better?? Its a perfect High dollar crank too boot, thats already balanced.. These rods are Bill Miller and are actually 6.525, with the smaller .990 pin...
[Re: MRMOPAR]
#1170330
02/03/12 10:42 AM
02/03/12 10:42 AM
gregsdart
Greg
OOps, you are correct! Mine had the 6.57 rods,,,,,,,,,
