6.535 rods with chrysler journals? #1170321
02/01/12 10:49 PM
02/01/12 10:49 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
any source for steel rods like these? Need a 6.535 rod, with standard 2.5/2.375 big end bore and .990 pin...
I have not found any yet?
Re: 6.535 rods with chrysler journals? [Re: Bob_Coomer] #1170322
02/02/12 01:55 AM
02/02/12 01:55 AM
Probally not going to find a stock off of the shelve rod, custom only, me thinks
Re: 6.535 rods with chrysler journals? [Re: Cab_Burge] #1170323
02/02/12 12:24 PM
02/02/12 12:24 PM
dogdays Offline
dogdays  Offline
6.535 is a bigblock chevy +0.400 length, as you already know. I can't remember ever seeing a rod in that length with anything but a 2.200" crankpin size.
I look at catalogs a lot.
R.
Re: 6.535 rods with chrysler journals? [Re: Bob_Coomer] #1170324
02/02/12 01:07 PM
02/02/12 01:07 PM
gregsdart Online content
gregsdart  Online Content
BME made aluminum rods for Indy Cyl Heads with those exact dimensions. Had a set in a 499 build years ago. BME will make them I am sure, might be able to scrounge a set still on a shelf. I know you asked for steel, but I don't remember anyone making them?
Re: 6.535 rods with chrysler journals? [Re: gregsdart] #1170325
02/02/12 07:00 PM
02/02/12 07:00 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
There must be a good answer to this.............
Why not grind the crank to 2.200?
Re: 6.535 rods with chrysler journals? [Re: AAR-B4] #1170326
02/02/12 11:05 PM
02/02/12 11:05 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Greg
INDY supplied a BME 6.570 rod with MOPAR journals for my 528" low deck. I never saw a 6.535 with MOPAR journals in the INDY catalog..
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: 6.535 rods with chrysler journals? [Re: AAR-B4] #1170327
02/02/12 11:44 PM
02/02/12 11:44 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
That is what I just had done to run a chev 6.535 rod.
Re: 6.535 rods with chrysler journals? [Re: AAR-B4] #1170328
02/02/12 11:48 PM
02/02/12 11:48 PM
Rock Springs
Rock Springs
It's cheaper to buy new rods than grind the crank...
I have thought about it..
work on the crank alone would probably be expensive... grinding and retreating...then rebalancing, then your still buying new rods. the loss in mass from journal size is negligible in this engine... Worth zero power, but I guess makes it fit better?? Its a perfect High dollar crank too boot, thats already balanced..
These rods are Bill Miller and are actually 6.525, with the smaller .990 pin...
Re: 6.535 rods with chrysler journals? [Re: Bob_Coomer] #1170329
02/02/12 11:56 PM
02/02/12 11:56 PM
Arizona
Chris'sBarracuda Offline
Arizona
It couldn't cost this much to cut down a crank to 2.200..
http://www.bmeltd.com/pdf_files/rod%20price%202010%20%282%29.pdf
Chris..
Re: 6.535 rods with chrysler journals? [Re: MRMOPAR] #1170330
02/03/12 10:42 AM
02/03/12 10:42 AM
Greg
OOps, you are correct! Mine had the 6.57 rods,,,,,,,,,
Re: 6.535 rods with chrysler journals? [Re: Bob_Coomer] #1170331
02/03/12 11:52 AM
02/03/12 11:52 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
You have a PM.
