Page 1 of 3 1 2 3
Green assembly line oil filter question? #1169978
02/01/12 12:46 PM
02/01/12 12:46 PM
What years were the green assembly line oil filters put on cars? I think 1972 is when they switched over to the red, white, and blue ones but what year did they start with the green ones?
Re: Green assembly line oil filter question? [Re: ] #1169979
02/01/12 06:21 PM
02/01/12 06:21 PM
Anyone????
Re: Green assembly line oil filter question? [Re: ] #1169980
02/01/12 09:43 PM
02/01/12 09:43 PM
S.W. Florida
blkbee6pack Offline
blkbee6pack  Offline
S.W. Florida
I know they did in 1970, I have two, one is rough (sand) finish and one is smooth finish. Both are green with embossed M on the end and part number L-72
Re: Green assembly line oil filter question? [Re: ] #1169981
02/02/12 10:28 AM
02/02/12 10:28 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Don't hold me to it, but I always thought the green textured filter with the embossed M showed up early-mid sixties
Re: Green assembly line oil filter question? [Re: gtx6970] #1169982
02/02/12 10:43 AM
02/02/12 10:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Don't hold me to it, but I alwasys thought the green textured filter with the embossed M showed up early-mid sixties
What is the part number ? I want to say it's very early 60's
Re: Green assembly line oil filter question? [Re: JohnRR] #1169983
02/02/12 11:31 AM
02/02/12 11:31 AM
L-72 1851 658
Re: Green assembly line oil filter question? [Re: ] #1169984
02/02/12 12:52 PM
02/02/12 12:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
L-72 1851 658
That part number is late 50's
Re: Green assembly line oil filter question? [Re: JohnRR] #1169985
02/02/12 01:14 PM
02/02/12 01:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it's also early to mid 70's but it's well known the pt # was applied to numerous filters
Re: Green assembly line oil filter question? [Re: gtx6970] #1169986
02/02/12 01:22 PM
02/02/12 01:22 PM
ok so late 50s to early/mid 70s then?
Re: Green assembly line oil filter question? [Re: JohnRR] #1169987
02/02/12 01:50 PM
02/02/12 01:50 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
yes, same part number, but the part changed throughout the years
Re: Green assembly line oil filter question? [Re: TONY_DAGOSTINO] #1169988
02/02/12 02:04 PM
02/02/12 02:04 PM
part changed how? appearance? color? raised M vs. the raised triangle with recessed center?
Re: Green assembly line oil filter question? [Re: ] #1169989
02/02/12 02:35 PM
02/02/12 02:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
primarily appearence changes .
color, same pt #
Colors - 3 that I know of - all white, red white and blue, green ( and there was actually 2 shades of the green )
green one was even with and without the embossed M
Green one was with and without the texture on the can
Everyone of them was serviced under the same pt #1851658
Re: Green assembly line oil filter question? [Re: gtx6970] #1169990
02/02/12 02:39 PM
02/02/12 02:39 PM
any break down for the years when those different ones would have been? I seem to recall the red, white, and blue one being 1972 and after.
Re: Green assembly line oil filter question? [Re: ] #1169991
02/03/12 02:34 AM
02/03/12 02:34 AM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Anyone have some good close-up photos they can post of the green filter? Need all around photos.
Thanks, Dan
Re: Green assembly line oil filter question? [Re: sixpaktoogo] #1169992
02/03/12 12:20 PM
02/03/12 12:20 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Green 1851658 green rough texture filters started use in 1966 as seen on the box on the right 10-26-6.
The later boxes had no date and these filters were used up until and including 1971.
I believe they were painted in batches over the years which accounts for some shade variation.
Re: Green assembly line oil filter question? [Re: mccannix] #1169993
02/03/12 12:25 PM
02/03/12 12:25 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Easy to remember...red, white and blue for 72....( and later, as seen with this 73 dated filter ).
Re: Green assembly line oil filter question? [Re: mccannix] #1169994
02/03/12 12:35 PM
02/03/12 12:35 PM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
Has anyone figured out what the "texture" is? Doesn't appear to be sand, but maybe I'm wrong. How were they painted - sprayed or dipped? Looks as if the "texture" is in the paint, not applied after being painted.
Thanks, Dan
Re: Green assembly line oil filter question? [Re: mccannix] #1169995
02/03/12 12:43 PM
02/03/12 12:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Also looks like the tooling was showing a bit of wear in it's later years based on the M on the left hand example
Re: Green assembly line oil filter question? [Re: mccannix] #1169996
02/03/12 12:56 PM
02/03/12 12:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Do you have any other pictures of this filter? I'd like to paint some up to resemble the correct one for my 73.
Re: Green assembly line oil filter question? [Re: burdar] #1169997
02/03/12 03:11 PM
02/03/12 03:11 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Front
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Page 1 of 3 1 2 3
