Do I need zinc additive? #1169931
02/01/12 11:52 AM
02/01/12 11:52 AM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I should have thought of this sooner; should I be using a zinc additive in my stock 1980 E58 Aspen?
Thanks.
Facts are stubborn things.
Re: Do I need zinc additive? [Re: larrymopar360] #1169932
02/01/12 12:00 PM
02/01/12 12:00 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
If it were me- Anything made before 1990 gets Zinc additive- or I run Delvac or Rotella or comparable diesel oil. Not the synthetic though. The standard diesel oils have a high zinc content.
Run a search of the forum, you will find a number of posts about this topic.
CC.
Re: Do I need zinc additive? [Re: larrymopar360] #1169933
02/01/12 01:30 PM
02/01/12 01:30 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Re: Do I need zinc additive? [Re: larrymopar360] #1169934
02/01/12 01:59 PM
02/01/12 01:59 PM
Locomotion Offline
Locomotion  Offline
It depends on the oil. But you have to do some looking and research because many of the newer diesel oils have had significant reductions in zinc and phosphorous content also.
If you prefer the added benefits of synthetics, Amsoil has a wide range of high zinc oils to choose from.
Amsoil Technical Bulletin on zinc
Amsoil source and additional info.
Re: Do I need zinc additive? [Re: chargincharles] #1169935
02/01/12 03:48 PM
02/01/12 03:48 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
anything I own NON roller gets it, Hell even my Full roller 408 gets it. Its good oil, and parts like it.
Im a Brad Penn guy, so everything I own except my 07 Charger, and my 79 John Deere 4230 gets brad penn, 2 harleys, my Demon, my Ramcharger, my 78 power wagon, everything.....
there is Brad penn 10w30
Kasey
Re: Do I need zinc additive? [Re: larrymopar360] #1169936
02/02/12 02:13 AM
02/02/12 02:13 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I know there are varying views on this, but I am a little concerned about synthetic in it due to very high mileage. I will at least use an additive now though. Thanks.
Re: Do I need zinc additive? [Re: larrymopar360] #1169937
02/02/12 08:47 AM
02/02/12 08:47 AM
BDW Offline
BDW  Offline
Hard to beat Lucas for the money.
One bottle of the break-in additive will do 3-4 oil changes.
Local Advanced Autos carry it too, so no shipping.
Re: Do I need zinc additive? [Re: BDW] #1169938
02/02/12 10:11 AM
02/02/12 10:11 AM
scratchnfotraction Offline
a small bottle of STP will do fine
the red bottle for 4 cyls has more than the blue on the ZDDP
lucas/hughes/comp/GM break in additives will work.
I just use a blue bottle of STP in my 440 with a 10/30 napa house brand oil change.
I use a napa gold filter on all of mine
my roller cam in the SB gets a bottle of STP and the 10/30 oil also,cant hurt to run I geuss..but I did go roller for this reason,and its now in the 2nd engine with different roller lifters this time.
no need for to much snake oil additives,i think some of the gas tretment might help carbon up the valves like mine were
I am cheap and use the STP from walmart for 2.00$ a bottle
Re: Do I need zinc additive? [Re: chargincharles] #1169939
02/02/12 10:29 AM
02/02/12 10:29 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
CC.
Weren't the diesel oils changed about 4 years ago though ?
I would say he wants an ADDITIVE , how is break in lube formulated compared to an additive.
I think the best oil is one that has the zinc in it .
Re: Do I need zinc additive? [Re: JohnRR] #1169940
02/02/12 12:32 PM
02/02/12 12:32 PM
CC.
would 5 qrts of STP be enuff ZDDP?
I have used 2-3 qrts to quiet the rod knock down before..be me thinks it was a little to late at the time for ZDDP to save it.
Re: Do I need zinc additive? [Re: scratchnfotraction] #1169941
02/02/12 12:41 PM
02/02/12 12:41 PM
dogdays Offline
dogdays  Offline
For a stock 360? Guys, get real. Stock valve springs that have way less than 100# seat pressure, already broken in, with a .4" lift cam? Whatever oil you buy will have plenty of lubrication power. There are literally millions of flat tappet stock engines running around using whatever oil Grease Monkey puts in with no failures.
Find something more important to worry about. Like the high price of arugula at your local grocer's (No_Politics reference).
R.
Re: Do I need zinc additive? [Re: dogdays] #1169942
02/02/12 12:50 PM
02/02/12 12:50 PM
JohnRR Offline
JohnRR  Offline
R.
Re: Do I need zinc additive? [Re: scratchnfotraction] #1169943
02/02/12 12:51 PM
02/02/12 12:51 PM
JohnRR Offline
JohnRR  Offline
CC.
The zinc is for the cam and lifters not the bearings.
Re: Do I need zinc additive? [Re: larrymopar360] #1169944
02/02/12 12:59 PM
02/02/12 12:59 PM
MA
1968 Charger B5 Offline
MA
I tend to run VR-1 in my cars, 20w-50 during hot months...
OR rotella...
However...I will say one thing....
I have an 87 Ramcharger that I installed a rebuilt 440...when i broke the engine in I did the usual...run at different rpms for 1/2 hour holding, and used straight30w detergent oil....HOWEVER, since then, it gets whatever cheap-ass-shitty oil I can buy on discount from whatever store....it was my daily driver from 98-07 with that engine....now its a plow truck, but the engine starts and runs just fine...all this zinc talk...and the cheap oil never had ANY effect on the 440.....maybe its just a testament to how great Mopar engines are...
Rick
1968 Dodge Charger R/T
1971 Plymouth Roadrunner
1998 Jeep Cherokee
Re: Do I need zinc additive? [Re: 1968 Charger B5] #1169945
02/03/12 02:18 PM
02/03/12 02:18 PM
dogdays Offline
dogdays  Offline
No, it's a testament to how stock cams and wimpy valve springs don't need much lubrication to survive.
R.
Re: Do I need zinc additive? [Re: JohnRR] #1169946
02/03/12 07:39 PM
02/03/12 07:39 PM
CC.
you didnt get it did you John?
Re: Do I need zinc additive? [Re: scratchnfotraction] #1169947
02/04/12 04:30 AM
02/04/12 04:30 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
If a little zinc additive won't hurt it I would rather have it for extra peace of mind. It is a high mileage stock E58. I would feel better with it. Mike: I am going to run a fuel system cleaner thru it too, thanks.
Re: Do I need zinc additive? [Re: larrymopar360] #1169948
02/04/12 08:36 PM
02/04/12 08:36 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I'd be willing to bet any diesel oil will have plenty ZDDP in it for a stock 360.
Rotella synthetic blend?
I bought a bunch of STP oil stabilizer. (no longer made) Nothing to use it in right now.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Do I need zinc additive? [Re: Rug_Trucker] #1169949
02/05/12 04:36 PM
02/05/12 04:36 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
FWIW, todays heavy duty (diesel oil) all fleet dino engine oil averages 1200 ppm zddp. Plenty for a stock(ish) engine. I run the 15W40 Shell Rotella. Broke in my .518" lift cam with the stuff and a splash of STP. The synthetic HDEO is a little higher in zddp.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Do I need zinc additive? [Re: larrymopar360] #1169950
02/05/12 05:58 PM
02/05/12 05:58 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Thanks.
The cheapeast wallmart brand oil available today is lightyears ahead of the best oil in the 70s/80s/ most of the 90s. Imo, I wouldn't worry about adding zinc. Especially in a hydraulic cammed engine.
