fuel pump relay #1169751
02/01/12 01:41 AM
02/01/12 01:41 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
how far away from the pump are your relays?
Re: fuel pump relay [Re: bonefish] #1169752
02/01/12 01:46 AM
02/01/12 01:46 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my pump is in the trunk 4" away from the battery, the relay is inbetween. i guess you could say they're close.
Re: fuel pump relay [Re: bonefish] #1169753
02/01/12 01:48 AM
02/01/12 01:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
About 8"
Re: fuel pump relay [Re: MR_P_BODY] #1169754
02/01/12 02:15 AM
02/01/12 02:15 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
About 8 feet actually. I have a relay box in both cars. One has the pump in the trunk and the other has it in the front by the cell.
Re: fuel pump relay [Re: bonefish] #1169755
02/01/12 10:14 AM
02/01/12 10:14 AM
an8sec70cuda Offline
My battery is in the trunk, relay is right next to it, and the fuel pump is mounted on the frame rail right under the battery.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: fuel pump relay [Re: bonefish] #1169756
02/01/12 01:04 PM
02/01/12 01:04 PM
ohio
top comp Offline
top comp  Offline
ohio
my relay is is mounted at the pump in the rear,batt. is in the trunk. main power wire runs from the batt. switch to the relay 16 inches/from the relay to to the pump 6 inches( 12 gauge wire)
Re: fuel pump relay [Re: an8sec70cuda] #1169757
02/01/12 01:48 PM
02/01/12 01:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
DITTO.............
Re: fuel pump relay [Re: Thumperdart] #1169758
02/01/12 02:53 PM
02/01/12 02:53 PM
Cab_Burge Online work
Cab_Burge  Online Work
DITTO.............
Me too
Re: fuel pump relay [Re: Cab_Burge] #1169759
02/01/12 05:43 PM
02/01/12 05:43 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Mine are close too. I'm running 2 - 40 amp relays to reduce the electrical load on each one of them.
Re: fuel pump relay [Re: Cab_Burge] #1169760
02/01/12 09:04 PM
02/01/12 09:04 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
DITTO.............
Me too
DITTO 3
Re: fuel pump relay [Re: Sport440] #1169761
02/01/12 11:44 PM
02/01/12 11:44 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
right now probably about 50 feet because the pump is in the front of the car which is in the trailer, the relays are in a tackle box in the shop. i don't use a relay for a 7 amp load there's no reason to but to each his own.
Re: fuel pump relay [Re: an8sec70cuda] #1169762
02/02/12 12:29 AM
02/02/12 12:29 AM
IN
ahy Offline
ahy  Offline
IN
Me too. Why do you ask?
Re: fuel pump relay [Re: ahy] #1169763
02/02/12 12:49 AM
02/02/12 12:49 AM
jamesc Offline
jamesc  Offline
it's worth noting that if people insist on using relays you should switch the relay to ground to operate it that way you don't have another positive circuit running through the car and the potential short that goes with it
Re: fuel pump relay [Re: jamesc] #1169764
02/02/12 01:01 AM
02/02/12 01:01 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I knew thats where you were going with this on your last post. Thats how mine is.
But set up that way, you want to utilize a master cut off.
Re: fuel pump relay [Re: Sport440] #1169765
02/02/12 01:07 AM
02/02/12 01:07 AM
jamesc Offline
jamesc  Offline
absolutely...i know i shouldn't have but assumed that anyone doing this kinda stuff would automatically have a battery disconnect
