Re: fuel pump relay
[Re: bonefish]
#1169752
02/01/12 01:46 AM
02/01/12 01:46 AM
Posts: 4,647 aotearoa
rebel
aotearoa
my pump is in the trunk 4" away from the battery, the relay is inbetween. i guess you could say they're close.
Re: fuel pump relay
[Re: bonefish]
#1169753
02/01/12 01:48 AM
02/01/12 01:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
how far away from the pump are your relays?
About 8"
Re: fuel pump relay
[Re: MR_P_BODY]
#1169754
02/01/12 02:15 AM
02/01/12 02:15 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
About 8 feet actually. I have a relay box in both cars. One has the pump in the trunk and the other has it in the front by the cell.
Re: fuel pump relay
[Re: bonefish]
#1169755
02/01/12 10:14 AM
02/01/12 10:14 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
My battery is in the trunk, relay is right next to it, and the fuel pump is mounted on the frame rail right under the battery.
Re: fuel pump relay
[Re: Cab_Burge]
#1169759
02/01/12 05:43 PM
02/01/12 05:43 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Mine are close too. I'm running 2 - 40 amp relays to reduce the electrical load on each one of them.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: fuel pump relay
[Re: Cab_Burge]
#1169760
02/01/12 09:04 PM
02/01/12 09:04 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
DITTO.............
Me too
DITTO 3
Re: fuel pump relay
[Re: an8sec70cuda]
#1169762
02/02/12 12:29 AM
02/02/12 12:29 AM
Posts: 7,664 IN
ahy
IN
Me too. Why do you ask?
Re: fuel pump relay
[Re: jamesc]
#1169764
02/02/12 01:01 AM
02/02/12 01:01 AM
Sport440
Canton, Ohio
it's worth noting that if people insist on using relays you should switch the relay to ground to operate it that way you don't have another positive circuit running through the car and the potential short that goes with it
I knew thats where you were going with this on your last post. Thats how mine is.
But set up that way, you want to utilize a master cut off.
Re: fuel pump relay
[Re: Sport440]
#1169765
02/02/12 01:07 AM
02/02/12 01:07 AM
Posts: 5,875 communist bloc of new jersey
jamesc
absolutely...i know i shouldn't have but assumed that anyone doing this kinda stuff would automatically have a battery disconnect
