Solid roller Lifters..How Long before rebuild? #1169365
01/31/12 02:47 PM
01/31/12 02:47 PM
Fairfield Maine
hemi4speed Offline OP
Fairfield Maine
I have a Extreme Energy Street roller cam in My street hemi. I have less than 1200 miles on since engine rebuilt 3 yrs ago, some street and track time. Change the oil twice a summer (short summers up here in Maine lol!) I roll the engine over every 2 weeks in the winter.
When should I send the lifters to get rebuilt?
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169366
01/31/12 04:19 PM
01/31/12 04:19 PM
Fairfield Maine
Fairfield Maine
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169367
01/31/12 04:29 PM
01/31/12 04:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd just replace them next time you rebuild the engine. They surely don't any attention after 1200 miles. Might want to adjust the valves, but the roller lifters are fine for a long time.
Re: Solid roller Lifters..How Long before rebuild? [Re: Challenger 1] #1169368
01/31/12 05:22 PM
01/31/12 05:22 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I know the chevy guys are proud to get 1500-3000 miles on thiers. But they use the little wheels and finally have the lifter bores opened up to Mopar sizes.
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169369
01/31/12 07:14 PM
01/31/12 07:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What spring pressure and what lifter? With the mild ramps on that cam, the likely relatively low spring pressures, possibly never with a high quality lifter.
Re: Solid roller Lifters..How Long before rebuild? [Re: BSB67] #1169370
01/31/12 10:26 PM
01/31/12 10:26 PM
Fairfield Maine
Fairfield Maine
valves springs com 954-16 Seat Pressure (lbs.) : 210 lbs. @ 1.900 in.
Open Pressure (lbs.) : 523 lbs. @ 1.250 in spring rated at 483 lbs.
comp cam roller Lifters. I forgot the #'s I paid like 350.00 +- for them. The cam int/exh 597/584 lift Duration int/exh 248/242 @ 50*
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169371
02/01/12 12:05 AM
02/01/12 12:05 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
One of the writers for popular hotroding magazine got 12000 miles out of his comp solid roller lifters before they went south, he also never checked the lash. He admited he did not know how.
And that was in a SB chevy.
Re: Solid roller Lifters..How Long before rebuild? [Re: Darryls-Demon] #1169372
02/01/12 12:19 AM
02/01/12 12:19 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Also depends on the type of driving you do. If there's a lot of low rpm stuff, a more strict schedule is in order due to the lack of oil flying around to help lubricate things. If you have pressure fed axles on the lifters, disregard what I just wrote.
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169373
02/01/12 12:21 AM
02/01/12 12:21 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Great looking car you got there.
I pull them out every so often, clean them up in solvent and spend some time time checking them for "sticky wheels" or bearings that feel funny. Usually when a bearing gets damaged, one of the rollers will get a flat spot on it that you can feel just by rolling the wheel in the palm of your hand. If nothing found, oil them up again and reinstall.
Yours might be fine, but it might be nice to have a look.
It's either do that, or the other approach: keep an eye on the valve lash, and pay attention to the noise. If one ever gets noisy and opens up suddenly, don't run it any more...not at all....if you're on the road, call a rollback.
I'm overdue to check mine out and will probably do it this year.
Rich H.
Esse Quam Videri
Re: Solid roller Lifters..How Long before rebuild? [Re: Darryls-Demon] #1169374
02/01/12 12:22 AM
02/01/12 12:22 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i run a comp,649,654 gross lift cam and my head mech.recomended 1,200 mi. then atleast check them or send them in for rebuild.
Re: Solid roller Lifters..How Long before rebuild? [Re: ZIPPY] #1169375
02/01/12 12:38 AM
02/01/12 12:38 AM
Fairfield Maine
Fairfield Maine
Great info guys, so far I'm checking valve lash and keeping my ears open to any one lifter louder than the rest. I posted this as I didnt want to send them out for rebuild prematurely or have a catastrophic failure..Thanks for the kudo's my X..Zippy.
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169376
02/03/12 05:17 PM
02/03/12 05:17 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I've gone close to 8000mi on a set of Comp 928 lifters. This is a mild street roller with 190 on the seat and 450 over the nose. I finally chickened out a bought a set of Crane Ultra Pro lifters. I've pulled two of the Comps out (pretty tricky to do in a Hemi with intake on) and they look good. Once I pull the intake I'll look at the rest before swapping them.
Re: Solid roller Lifters..How Long before rebuild? [Re: hemi4speed] #1169377
02/04/12 01:57 AM
02/04/12 01:57 AM
ohio
silverhemiboy Offline
ohio
I haven't looked at mine, but i believe they have approx 1300 miles on them. I just check the valve lash and so far everything seems to be ok.I only have a small cam with 254/284 @.050 duration. How's the green hemi running? I'll have to give you a call. Best regards.
Re: Solid roller Lifters..How Long before rebuild? [Re: silverhemiboy] #1169378
02/04/12 10:35 PM
02/04/12 10:35 PM
Fairfield Maine
Fairfield Maine
Running excellent Bill..Just trying maintain it properly. call anytime, thanks Rick
