Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116812
09/09/08 02:51 PM
09/09/08 02:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Repeat the above on the other side and presto! Shiney original bubble material with no sanding scratches (which is what ruins the tiny original details). After doing basic spot repairs (cracks etc.) I use a good sandable primer to coat everything, when sanding stop when you see white show through and you'll avoid damaging the original material which is VERY easy to sand away, it's like chalk.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116813
09/09/08 02:54 PM
09/09/08 02:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This stripper worked well. I've also used the made for metal "Aircraft" stripper with similar results, non had any adverse affects on the original base material no matter how long it was sitting on the part.
Do it in an open area far away from anything painted or nice because if it gets on pretty much anything it's toast!
ALWAYS wear eye protection and full cover of clothing, it spatters and splashes easily and always goes where you least expect....And...IT BURNS YOU FAST! BTW, Latex gloves WILL MELT when in contact with paints stripper, I used PVC gloves which resist it much better.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116814
09/09/08 02:58 PM
09/09/08 02:58 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Thanks Scott... Next time you are in Florida why don't you stop by the house and repair mine for me?
Darren
Re: Stripping paint from plastic [Re: Ludington1] #116815
09/09/08 03:05 PM
09/09/08 03:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tell you what? You strip it and send it to me, I'll repair it and send it back with a bill?
Or......You can let me strip it, repair it, paint it, and send you a BIGGER bill.
It's your call, your money or your flesh.
Loss of flesh is the reason I charge extra for paint stripping, it's my least favorite thing to do. It took me roughly 5 hours to completely strip the example above, time varies with every example but the mess is always the same.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116816
09/09/08 07:22 PM
09/09/08 07:22 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Those are made from ABS plastic which means that paint stripper will attack it. Try laquer thinner, it's safe for sure, also plain old DOT 3 brake fluid is safe and should also do it but it's pretty messy, typically you'll need to soak them in it for a good long while. Actetone and other solvents may also attack the plastic.
Laquer thinner will not harm interior plastic trim like those A-pillars. I've personally done it a ton of times. I've evan used it to clean door panels(vinyl) to prep them for a redye. I've never tried the DOT 3 but need to someday because I got some stubborn dye on some decent but faded interior plastics for F-bodies that just doesnt want to let go with the laquer thinner. The one benifit using the laquer thinner, if it will take the old dye off is, it will be ready to paint when your done getting it off. Now with the brake fluid your going to have to make sure to get it, meaning the brake fluid , all off there really good or its going to mess up your redye.
Re: Stripping paint from plastic [Re: mopowergtx] #116817
09/13/08 01:14 PM
09/13/08 01:14 PM
Renton, Washington
Bobster Offline OP
Bobster  Offline OP
Renton, Washington
I have to give a shout out to Scott at Harm's Auto for the brake fluid tip. It worked like a charm!
Thanks to everyone else for some great tips working with other materials as well.
Re: Stripping paint from plastic [Re: Bobster] #116818
09/21/08 05:42 PM
09/21/08 05:42 PM
What would work on stripping paint off of items such as plastic grilles and such?
