Stripping paint from plastic #116792
09/07/08 05:09 PM
09/07/08 05:09 PM
Renton, Washington
Bobster Offline OP
Bobster  Offline OP
Renton, Washington
Hey everyone.
I have a small problem. I have a pair of original Dodge Challenger A-Pillar plastic covers that have been painted. They are originally white and some idiot before me painted them black.
Is there a way to strip the paint off these things without damaging the plastic? Are there any techniques that I can employ that can do this?
The Forum's help is always appreciated!
Re: Stripping paint from plastic [Re: Bobster] #116793
09/07/08 05:51 PM
09/07/08 05:51 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
try mineral sperits on a small area...
Re: Stripping paint from plastic [Re: Bobster] #116794
09/07/08 05:54 PM
09/07/08 05:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Those are made from ABS plastic which means that paint stripper will attack it. Try laquer thinner, it's safe for sure, also plain old DOT 3 brake fluid is safe and should also do it but it's pretty messy, typically you'll need to soak them in it for a good long while. Actetone and other solvents may also attack the plastic.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116795
09/07/08 06:34 PM
09/07/08 06:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used DOT 3 on the grille in my sig car. Some idiot had painted it black as well. Was all flaking off and looked like crap. I sprayed brake fluid all over it, let it sit in the hot sun for a few hours and the paint just fell right off of it. I gave the grille a good washing and a fresh coat of paint and it looks like new.
Re: Stripping paint from plastic [Re: DaytonaTurbo] #116796
09/07/08 06:41 PM
09/07/08 06:41 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
autozone sells a aerosol paint stripper for plastic bumpers. works awesome but can get a little pricey if you need multiple cans
Re: Stripping paint from plastic [Re: prochargedhemi] #116797
09/07/08 08:20 PM
09/07/08 08:20 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I've had great results using Castrol Super Clean degreaser to strip plastic. I used it to strip the dash in my Barracuda of old chrome plating & paint. I also use it on vintage model cars I rebuild.
`68 Barracuda 340-S
Re: Stripping paint from plastic [Re: FASTBACK340] #116798
09/07/08 09:10 PM
09/07/08 09:10 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I had a post on Castrol Super Clean, from what I have read it's gone. At least I can't find it anymore.
Re: Stripping paint from plastic [Re: JonC] #116799
09/07/08 10:50 PM
09/07/08 10:50 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
The castrol purple cleaner at full strength works and I have had great result using oven cleaner, dont get the cheapo brand, never any harm to the plastic.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Stripping paint from plastic [Re: mopargem] #116800
09/07/08 11:47 PM
09/07/08 11:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You guys need to understand that all plastics are not created equal, some are resistant to nearly any chemicals while others will melt big time with solvents mentioned here. You need to know which plastic you have before using paint removers...PERIOD.
The part mentioned by the original poster is ABS, what I mentioned will work, anything else...BE CAREFUL! Oven cleaner is bad news to ABS or any other styrene based plastic
Re: Stripping paint from plastic [Re: Bobster] #116801
09/08/08 03:08 PM
09/08/08 03:08 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Check out SEM paints web site for some good directions on what solvents to use with what types of plastic.
I am in the process of completely re-doing the interior of my coupe...so far they stuff has worked great!
Re: Stripping paint from plastic [Re: Diplomat360] #116802
09/08/08 09:25 PM
09/08/08 09:25 PM
Renton, Washington
Bobster Offline OP
Bobster  Offline OP
Renton, Washington
Great! Thank you to everyone for the input!
My interior is black so I figured that I can at least spiff these up and find a good home for them.
Best of all, I learned something new in the process. I should have thought of the DOT 3 brake fluid before.
Re: Stripping paint from plastic [Re: Bobster] #116803
09/08/08 10:21 PM
09/08/08 10:21 PM
Hey there is one thing that worked great for model cars that I have used to strip all paint no matter the age of paint 409 house cleaner. stick it in a container and submerge it walk away it will strip it
Preston
Re: Stripping paint from plastic #116804
09/09/08 06:59 AM
09/09/08 06:59 AM
Ky.
dart67 Offline
dart67  Offline
Ky.
Why not 600 grit sand paper?
Re: Stripping paint from plastic [Re: dart67] #116805
09/09/08 09:46 AM
09/09/08 09:46 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Because sand paper does not know the difference between removing paint or plastic. If you don't mind losing some fine details and don't mind missing areas in corners where you simply cant sand, sand away.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116806
09/09/08 01:51 PM
09/09/08 01:51 PM
Manitoba, Canada
Manitoba, Canada
You have to watch with that castrol super clean. I tried some on some plastic parts years ago, that stuff turned them to mush. So be careful with what stripping agents you use on what kinds of plastic.
Re: Stripping paint from plastic [Re: DaytonaTurbo] #116807
09/09/08 02:02 PM
09/09/08 02:02 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Scott,
What would you recommend for an original shaker bubble and e-body door panels?
Thanks!
Darren
Re: Stripping paint from plastic [Re: Ludington1] #116808
09/09/08 02:43 PM
09/09/08 02:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Fiberglass safe paint stripper on the bubbles. On door panes (Polypropylene) is pretty much impossible to melt with chemicals ( in fact most plastic jugs that hold chemicals are made of Polypropylene) so you can use most anything on the door panels. It's always a good idea to start with something mild like laquer thinner and work towards stronger chemicals should it not get the job done, Acetone would be my next try if LT doesn't work.
Here's a bubble I recently stripped for repairs.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116809
09/09/08 02:45 PM
09/09/08 02:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Next step, add paint stripper to one half and let it work it's magic
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116810
09/09/08 02:46 PM
09/09/08 02:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I stripped one half at a time for demonstration purposes plus it's nice to have a dry area for handling it. This is after the first layer of stripper was washed/scraped off.
Re: Stripping paint from plastic [Re: ScottSmith_Harms] #116811
09/09/08 02:48 PM
09/09/08 02:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After anoher coat of stripper followed by some elbow grease and a non scratch version of scotch brite and water rinse.
