Help! Leaking 750 Holley #1167636
01/29/12 10:49 AM
01/29/12 10:49 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
I have a 750 Holley Carb that has developed a leak in the base of the carb. Didn't know it until I had trouble getting the car to run and picked it up off of the manifold and gas was running out of the small hole beside the base screw. The hole goes into the body of the carb from the base up into the cavity behind the power valve. Have changed power valve gaskets and it still gets fuel trough and runs out the bottom of the base. Any ideas how this happens and how to repair it?
Re: Help! Leaking 750 Holley [Re: chris3] #1167637
01/29/12 10:57 AM
01/29/12 10:57 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Picture might help
Re: Help! Leaking 750 Holley [Re: radar] #1167638
01/29/12 11:04 AM
01/29/12 11:04 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Change the power valve itself.
Re: Help! Leaking 750 Holley [Re: radar] #1167639
01/29/12 11:05 AM
01/29/12 11:05 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Have you tried a new baseplate gasket?
Sometimes a stopped up air bleed can cause leaks and drips. But, that said, never saw it cause one at the baseplate. I would dissamble the carb and clean all the passages. Check the base and main body for square. Put back together with a fresh base to main body gasket.
Sorry could not be more help. But, I am not sure without seeing the carb where your leak is or where it is coming from.
Leon
Re: Help! Leaking 750 Holley [Re: Leon441] #1167640
01/29/12 05:14 PM
01/29/12 05:14 PM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Level of certainty that's the source? Liquids (fuel, oil) are funny sometimes and will run along surfaces taking the fluid away from where it's actually leaking from.
If not absolutely certain, may be worth a few minutes of studying the leak a bit.
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Help! Leaking 750 Holley [Re: chris3] #1167641
01/29/12 08:32 PM
01/29/12 08:32 PM
Look real closely at the pump squirter circuit, make sure the gasket and or metering plate isn't allowing fuel into the back of the metering block. Ckeck the simple stuff first, power vale and gasket, warped metering block and so on Lots of challenges(Murphy Law ) out thier waiting to test are trouble shooting skills
