I have a 750 Holley Carb that has developed a leak in the base of the carb. Didn't know it until I had trouble getting the car to run and picked it up off of the manifold and gas was running out of the small hole beside the base screw. The hole goes into the body of the carb from the base up into the cavity behind the power valve. Have changed power valve gaskets and it still gets fuel trough and runs out the bottom of the base. Any ideas how this happens and how to repair it?
