440 Cam Timing Question
#1167446
01/28/12 09:16 PM
01/28/12 09:16 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
As some of you know I'm building this 440 with Stealth heads and a Summit 6401 cam. We degreed the cam today and here's what we got. Exh open 2 deg retarded Exh close. 4 deg advanced Int open 2 deg retarded Int close 1 deg retarded These are departures from spec. The crank sprocket has keyway options for 4 degree advance or retard. Are these differences worth worrying about for street car that will likely never see more than 4500 rpm? I entered the differences into my desktop dyne and there was no more than a 5hp difference either way. Thanks!
Re: 440 Cam Timing Question
[Re: 383man]
#1167449
01/29/12 11:43 AM
01/29/12 11:43 AM
bobs66440
Where did the intake centerline come out. Was it advanced or retarded or on spec ? Ron
Here is the cam card, what it's supposed to be...
I went out and double checked everything. This is what I got...
Int open - 1* BTDC = 2* retarded Int close - 41* ABDC = ON SPEC
Exh open - 54* BBDC = 2* retarded Exh close - 2* BTDC = 4* advanced
Lobe centerline - Int 109* ATDC = ON SPEC Lobe centerline - Exh 120* BTDC = 1* advanced
Thanks!
[Re: bobs66440]
#1167451
01/29/12 02:10 PM
01/29/12 02:10 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
How is your dial indicator set up off the lifter? variations in angle and such can affect @ .050. I like to do .050 and .100 before and after max lift /2 to get a good read on Intake max lift (intake centerline)
You are using a solid lifter I take it??
You indicating right off the lifter? indicator in pushrod in lifter (I have a short push rod made up for this! Or off the valve retainer?
[Re: bobs66440]
#1167452
01/29/12 02:49 PM
01/29/12 02:49 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
First, you've measured the intake at 222 degrees duration and the exhaust at 232 verses Summit having them at 224 and 234. Could be your measurements, or it could be the cam. I would not get too worked up about it.
Second, their "-2 BTDC" on the card is not 2 ATDC, it is simply 2 BTDC. I don't know why they would write it this way.
Therefore, both openings are a couple degrees retarded, and the closings are per the timing card.
The cam is ground with a 114 degree LSA, with a recommended 109 installed intake centerline (ICL) As you have it, it's installed at 110 degrees. You can leave as is.
[Re: BSB67]
#1167453
01/29/12 04:37 PM
01/29/12 04:37 PM
bobs66440
Do you think that applies to the difference in the 3 degree/-3 degree discrepancy in the two cards also?
