440 Cam Timing Question #1167446
01/28/12 09:16 PM
01/28/12 09:16 PM
Out in Left Field, NY
bobs66440 Offline OP
As some of you know I'm building this 440 with Stealth heads and a Summit 6401 cam. We degreed the cam today and here's what we got.
Exh open 2 deg retarded
Exh close. 4 deg advanced
Int open 2 deg retarded
Int close 1 deg retarded
These are departures from spec. The crank sprocket has keyway options for 4 degree advance or retard. Are these differences worth worrying about for street car that will likely never see more than 4500 rpm?
I entered the differences into my desktop dyne and there was no more than a 5hp difference either way.
Thanks!
Re: 440 Cam Timing Question [Re: bobs66440] #1167447
01/29/12 02:19 AM
01/29/12 02:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Where did the intake centerline come out. Was it advanced or retarded or on spec ? Ron
Re: 440 Cam Timing Question [Re: bobs66440] #1167448
01/29/12 03:38 AM
01/29/12 03:38 AM
Thanks!
Explain retarded in relation to Top Dead Center on both valve events please What is the duration (at .050 lift), lift and lobe seperation on that camshaft?
Re: 440 Cam Timing Question [Re: 383man] #1167449
01/29/12 11:43 AM
01/29/12 11:43 AM
Here is the cam card, what it's supposed to be...
I went out and double checked everything. This is what I got...
Int open - 1* BTDC = 2* retarded
Int close - 41* ABDC = ON SPEC
Exh open - 54* BBDC = 2* retarded
Exh close - 2* BTDC = 4* advanced
Lobe centerline - Int 109* ATDC = ON SPEC
Lobe centerline - Exh 120* BTDC = 1* advanced
Thanks!
Re: 440 Cam Timing Question [Re: bobs66440] #1167450
01/29/12 12:05 PM
01/29/12 12:05 PM
And just to confuse things, the cam card posted on the Summit site has a different spec for the "intake open" event than the card that came with the cam. One is 3* BTDC and the other is -3.
I'm not sure which one is correct...
Re: 440 Cam Timing Question [Re: bobs66440] #1167451
01/29/12 02:10 PM
01/29/12 02:10 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
How is your dial indicator set up off the lifter? variations in angle and such can affect @ .050. I like to do .050 and .100 before and after max lift /2 to get a good read on Intake max lift (intake centerline)
You are using a solid lifter I take it??
You indicating right off the lifter? indicator in pushrod in lifter (I have a short push rod made up for this! Or off the valve retainer?
Re: 440 Cam Timing Question [Re: bobs66440] #1167452
01/29/12 02:49 PM
01/29/12 02:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
First, you've measured the intake at 222 degrees duration and the exhaust at 232 verses Summit having them at 224 and 234. Could be your measurements, or it could be the cam. I would not get too worked up about it.
Second, their "-2 BTDC" on the card is not 2 ATDC, it is simply 2 BTDC. I don't know why they would write it this way.
Therefore, both openings are a couple degrees retarded, and the closings are per the timing card.
The cam is ground with a 114 degree LSA, with a recommended 109 installed intake centerline (ICL) As you have it, it's installed at 110 degrees. You can leave as is.
Re: 440 Cam Timing Question [Re: BSB67] #1167453
01/29/12 04:37 PM
01/29/12 04:37 PM
Do you think that applies to the difference in the 3 degree/-3 degree discrepancy in the two cards also?
