high amp switch #1167222
01/28/12 01:56 PM
01/28/12 01:56 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i use a 30 amp or bigger toggle switch is it still necassary to run a relay?
Re: high amp switch [Re: bonefish] #1167223
01/28/12 02:08 PM
01/28/12 02:08 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
What is the amp draw of wht your using the switch for and how far away from the switch?
I run relays for everything, but locate the relays close to what it's going to turn on. Fan and water pump up front, Fuel pump relay in the back...Everything else in the cab.
But I do know there are more than a few on here whom just use high amp switches...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: high amp switch [Re: bonefish] #1167224
01/28/12 05:29 PM
01/28/12 05:29 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Not necessary for just switching a relay..
As the relay is doing the heavy lifting, a 5A rating is more than enough just for the toggle switch..
Just my $0.02...
Re: high amp switch [Re: Sinitro] #1167225
01/30/12 06:49 PM
01/30/12 06:49 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Yeah he wasn't asking about a light duty switch used to activate a relay- he wants to know if it's ok to just use a high amp switch without a relay.
If it's for a high draw item I use a relay and get power right off the alternator. I use the stock harness for all the other interior functions. I have a bank of relays where the battery used to be- fans, fuel pump, headlights, horn. I use a switch for the rear defroster, um... that's it.
Re: high amp switch [Re: bonefish] #1167226
01/30/12 11:05 PM
01/30/12 11:05 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the switch is just part of the circuit, the wire size is as or more important. what are you looking to power?
Re: high amp switch [Re: jamesc] #1167227
01/31/12 01:30 PM
01/31/12 01:30 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this is just a race car.bg 400,elect wp,1 fan and msd7-AL3.
Re: high amp switch [Re: radar] #1167228
01/31/12 01:32 PM
01/31/12 01:32 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thats it,just the high amp switch, no relay.
Re: high amp switch [Re: bonefish] #1167229
01/31/12 02:22 PM
01/31/12 02:22 PM
jamesc Offline
jamesc  Offline
i'm not sure what you're looking to do but if you want to power all of those from one switch then imho i would not use a toggle type switch. i'm sure there are toggle switches made that will handle it but doubt they're very common. a cole hersee battery type switch would handle it fine but as mentioned i'm not sure what you're looking to do. also as i mentioned wire size is VERY (load and length dependent) important. although i can't remember the exact numbers and they do vary i have done (accurate) current draw tests on all of the accessories you mention. many people go overboard with wire sizing, relays and whatnot but you do not want to use wire that is too small.
iirc generally the loads are (rough numbers)
ignition (holley, MSD) 6-7 amps
water pump (shogun, teel) 6-7 amps
fuel pump (mallory comp 250) 6-7 amps
electric fan (flexalite black magic) 15 amps
trans brake (transmission specialties) 15 amps
Re: high amp switch [Re: jamesc] #1167230
01/31/12 04:17 PM
01/31/12 04:17 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You can get switches up to 75 amps for aircraft buss electrical systems. Run a copper bus bar then have a seperate switch for each system.
http://www.aircraftspruce.com/catalog/elpages/pullswitches.php
http://www.experimentalaircraft.info/articles/aircraft-electrical-systems-5.php
Re: high amp switch [Re: astjp2] #1167231
01/31/12 06:35 PM
01/31/12 06:35 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i want to run a seperate switch for each item witout a relay.
Re: high amp switch [Re: bonefish] #1167232
01/31/12 08:03 PM
01/31/12 08:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem doing it without relays is you have to
run large wire from the switch all the way to the item
being powered... if you dont run large enough you will
have lowered voltage... with a relay you run a small
gauge wire to trigger the relay... I prefer the relays
Re: high amp switch [Re: bonefish] #1167233
01/31/12 09:14 PM
01/31/12 09:14 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
You could use one of these along with some 00 gauge battery cable...
"These go to eleven", Nigel Tufnel
Re: high amp switch [Re: bonefish] #1167234
01/31/12 09:21 PM
01/31/12 09:21 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
i want to run a separate switch for each item without a relay.
WHY??? Do you not understand relays so you want to shy away from them? Or do you have a specific need to not use them?
I agree with P-body - that just using high amperage switches means running a lot of large diameter wires every where.
Such as the fuel pump. It is located in the back of the car near the battery. Install a relay in the fused #12 power wire from the battery disconnect switch to the pump. This is a nice short direct route between the power source and the high amperage load (fuel pump). Then you can use a #18 wire all the way up to the switch on the dash.
A relay is really just an electrically controlled high amperage switch.
Re: high amp switch [Re: ProStDodge] #1167235
01/31/12 10:01 PM
01/31/12 10:01 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its time to rewire my car and i was just tryin to get some feedback on the relay angle,right now everything haS its own relay and fuse so its no big deal either way.ive just heard of guys that dont run relays and was wondering if anyone here had done it..
Re: high amp switch [Re: bonefish] #1167236
02/01/12 12:10 AM
02/01/12 12:10 AM
jamesc Offline
jamesc  Offline
yes i have done it and am in the process of doing it right now. while relays may be required in some situations installing them in a circuit that is not really necessary adds complication and more potential failure points. use a wire sizing chart and choose the appropriate size conductor. in many circuits 16-14 gauge is sufficient, 12 should handle just about any normal load (except starting / charging obviously) encountered. there are a lot of factors that dictate wire sizing. the voltage, current draw, type of wire, type of load etc. i've done a lot of automotive wiring over the years and the vast majority of electrical problems i've seen stem from peoples inexperience and lack of understanding. poor craftsmanship and low quality materials have been the two most common causes of failures i've seen. poor connections cause resistance, resistance causes heat, heat causes increased resistance it's a snowball effect. use good wire, clean grounds, quality nylon connectors with extra metal sleeves (NOT THE VINYL JUNK FOUND EVERYWHERE) and a quality crimping tool. circuit protection is important electrical fires are notoriously hard to extinguish. these are some of the basic good quality components for successful wiring, in some cases i use weatherpack connectors. it's not practical for most people to invest this much in supplies or tooling but i've done enough to justify it and don't like electrical problems. i was recently doing voltage drop tests on a transbrake circuit and let me say the drop was a whole heck of a lot more (like 9.25 volts was present at the solenoid) than i would ever believe. i can also say that the brake in that car has never once failed to set.
