Cam bearing tool? #1167127
01/28/12 12:36 PM
01/28/12 12:36 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Anyone have their own for BB and how well do you like it?
Re: Cam bearing tool? [Re: mac56] #1167128
01/28/12 01:06 PM
01/28/12 01:06 PM
Minn
SportF Offline
SportF  Offline
Minn
I was lucky enough to have the tools to make one at work after hours, and I wish I would have had one years ago. I can put bearings in, correctly indexed to my likeing, and the bearings are cheap enough, why not put new ones in every re-fresh?.
Re: Cam bearing tool? [Re: SportF] #1167129
01/28/12 01:19 PM
01/28/12 01:19 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We have a Lisle Cam Bearing Tool . Works good
Re: Cam bearing tool? [Re: SportF] #1167130
01/28/12 01:33 PM
01/28/12 01:33 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Tom did you make individual plugs to drive each bearing in? Do you have a picture of the tool you made?
Re: Cam bearing tool? [Re: mac56] #1167131
01/28/12 01:35 PM
01/28/12 01:35 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Dad made one for our engines. I'll try and get some pictures when i go home tonight.
Re: Cam bearing tool? [Re: cl440] #1167132
01/28/12 01:37 PM
01/28/12 01:37 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
Re: Cam bearing tool? [Re: Diablo] #1167133
01/28/12 01:43 PM
01/28/12 01:43 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Hey DJ that would be great.
Re: Cam bearing tool? [Re: mac56] #1167134
01/28/12 01:47 PM
01/28/12 01:47 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i got one from MAC TOOLS,works great.
Re: Cam bearing tool? [Re: CHAPPER] #1167135
01/28/12 02:08 PM
01/28/12 02:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine looks just like the Lisle. Ron
Re: Cam bearing tool? [Re: mac56] #1167136
01/28/12 03:09 PM
01/28/12 03:09 PM
I bought one from Snap On and it looks exactly like the Lisle tool Works good for over 15 yrs now
Re: Cam bearing tool? [Re: mac56] #1167137
01/28/12 03:21 PM
01/28/12 03:21 PM
Minn
SportF Offline
SportF  Offline
Minn
I made 5 bearing drivers and 2 nylon support bushings. The nylon supports the shaft when installing a couple of the bearings to keep everything straight. The drivers are pretty easy to make on a lathe if you have the bushings in front of you to measure off of. I made this so the drivers fit about a 1/3 of the way down the shaft so both ends of the shaft can be located in the block to keep things square. The two outside bearings, front and back, then are located off of the already installed inside bearings.
Re: Cam bearing tool? [Re: SportF] #1167138
01/28/12 04:53 PM
01/28/12 04:53 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the lisle tool is most common i have one and it's ok (not great). the dura bond tool is imho superior but pricey. one thing i learned is to not install all the bearings then check the cam fit. put the first two in then check the fit and do it with each one after that, that way you can get a better idea which one might be causing problems if the cam is tight.
Re: Cam bearing tool? [Re: jamesc] #1167139
01/28/12 08:05 PM
01/28/12 08:05 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
This is what I made up a while ago...
Not shown in the pic is a rubber cone which slides over the tool to keep it inline with the engine.
Re: Cam bearing tool? [Re: BigBlockMopar] #1167140
01/28/12 08:30 PM
01/28/12 08:30 PM
Minn
SportF Offline
SportF  Offline
Minn
That is a very pretty tool!
Re: Cam bearing tool? [Re: SportF] #1167141
01/28/12 08:52 PM
01/28/12 08:52 PM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
That is very nice!
Re: Cam bearing tool? [Re: cl440] #1167142
01/28/12 11:38 PM
01/28/12 11:38 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I bought one of those a last summer to drive some cam bearings out/in and it worked great.
Re: Cam bearing tool? [Re: Cab_Burge] #1167143
01/28/12 11:41 PM
01/28/12 11:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mine is a Snap-On also.
Too late to comparison shop now...works just fine, no complaints. If I was starting over I'm not sure I wouldn't get the Lisle one instead.
Rich H.
Esse Quam Videri
Re: Cam bearing tool? [Re: 69Cuda340S] #1167144
01/29/12 12:21 AM
01/29/12 12:21 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
picked up one of those for 40 dollars off CL..have yet to use it yet...
Tony
70 AARCuda Vitamin C
Re: Cam bearing tool? [Re: cl440] #1167145
01/29/12 11:59 AM
01/29/12 11:59 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Besides cam bearings, I've used mine to knock in 727 bushings.
Re: Cam bearing tool? [Re: ZIPPY] #1167146
01/29/12 01:44 PM
01/29/12 01:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I got my isle thru the snap on dealer , It comes in handy for many things, like changing many of the bushings in a 727 .
