Oil Pans- What's correct? #1167030
01/28/12 10:58 AM
01/28/12 10:58 AM
SE Wisconsin, USA
RP's R/T's Offline OP
SE Wisconsin, USA
I thought my car had the original Oil Pan, but it doesn't. It's a 70 E-body, 440 + 6.
What are identifiers of the different years, capacities?
What is the significance of the 3-digit number on them?
Who makes the the best repro's? (I know I had seen someone at the Nats with them)
What would I expect to pay for an good original?
Re: Oil Pans- What's correct? [Re: RP's R/T's] #1167031
01/28/12 11:19 AM
01/28/12 11:19 AM
MD
floyd Offline
floyd  Offline
MD
Re: Oil Pans- What's correct? [Re: RP's R/T's] #1167032
01/28/12 11:25 AM
01/28/12 11:25 AM
ALABAMA
4406PAKCUDA Offline
4406PAKCUDA  Offline
ALABAMA
My original 70 440-6 doesn't have any #'s on the pan and it's the same 6 qt pan as the hemi's used in 70. I've seen several with 402 pans on them but I don't believe that's "correct".
Re: Oil Pans- What's correct? [Re: 4406PAKCUDA] #1167033
01/28/12 11:31 AM
01/28/12 11:31 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Yes, no numbers on a '70-'71 440HP, 440-6 and Hemi pan. The pan holds 6 qts with filter. MP reproduction is nice, P4529884. Make sure you get the correct 3/8" strainer to go with it.
Re: Oil Pans- What's correct? [Re: floyd] #1167034
01/28/12 02:55 PM
01/28/12 02:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
http://www.rosevillemoparts.com/reference_enginetrans3.php
402?
Looks like Tony has them for $145
The 402 is the 69 and older pan
No numbers on a 70 sixpack pan - the repo is close but not perfect
Re: Oil Pans- What's correct? [Re: Morty426] #1167035
01/28/12 03:07 PM
01/28/12 03:07 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
In '70 & '71 - the HEMI, 440+6 & 440HP used the same (no number) oil pan in E and B-bodies.
The 402 pan was used in '69 on b-bodies (earlier also) with 383s, 440HP, & 440+6 - it remained in use for '70 & '71 on E and B-bodies with 383s.
Re: Oil Pans- What's correct? [Re: 6bblgt] #1167036
01/28/12 04:03 PM
01/28/12 04:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I inspected a 70 Six Pak 'Cuda for a guy in California late last year and had to tell him it was not numbers matching after he put it on a lift so I could easily see the VIN number. To my suprise it had an 893 pan on it! I told him I would buy him a repro pan and change them out on my dime, he declined...
JB Rhinehart, Realist
A-Body's RULE!
Re: Oil Pans- What's correct? [Re: Rhinodart] #1167037
01/28/12 08:36 PM
01/28/12 08:36 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Oil Pans- What's correct? [Re: 440beep] #1167038
01/29/12 01:16 PM
01/29/12 01:16 PM
SE Wisconsin, USA
SE Wisconsin, USA
Is this what is available from Mopar?
Any modifications that need to be done to be accurate?
Re: Oil Pans- What's correct? [Re: RP's R/T's] #1167039
01/29/12 01:40 PM
01/29/12 01:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes and yes, paint it .
Re: Oil Pans- What's correct? [Re: B5 Bee] #1167040
01/31/12 06:41 PM
01/31/12 06:41 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Will an original 383 402 oil pan 3/8" pick-up work on a MP Hemi oil pan?
Re: Oil Pans- What's correct? [Re: CompSyn] #1167041
02/01/12 11:28 AM
02/01/12 11:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , the hemi pan is deeper than the 402 pan. The 3/8" pickup can be bought new from MP , last time I bought it it ws not very expensive , cheapest source I found was Summit .
Re: Oil Pans- What's correct? [Re: JohnRR] #1167042
02/01/12 01:33 PM
02/01/12 01:33 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Thanks, that's good to know. I've looked but haven't been able to find sold information on the MP pick-ups. What part number would I use for a 383 with Hemi pan and 3/8" sized pick-up?
Re: Oil Pans- What's correct? [Re: CompSyn] #1167043
02/01/12 01:43 PM
02/01/12 01:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
P4529565
Re: Oil Pans- What's correct? [Re: 6bblgt] #1167044
02/01/12 01:49 PM
02/01/12 01:49 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You are correct. I forgot that they carried over the 402 for the 383
Re: Oil Pans- What's correct? [Re: RP's R/T's] #1167045
02/01/12 02:08 PM
02/01/12 02:08 PM
Up in the North and Far Away
AutoEngineer Offline
You can buy that 6-pack oil pan also from here at $99.95
http://store.440source.com/1970-71-Hemi-E-Body-6-Quart-Oil-Pan/productinfo/200%2D1123/
Pick up $19.95
http://store.440source.com/Oil-Pickup-Tube-5-Deep-Sump-3_8-thread/productinfo/121%2D1055/
I just rebuild one 440 using those parts from 440Source and I can't complain
Re: Oil Pans- What's correct? [Re: JohnRR] #1167046
02/01/12 10:06 PM
02/01/12 10:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
P4529565
Okay, this is where I'm getting hung up.
The notes say the P4529565 is for - 6 Quart, 3/8" Pipe for "RB" Engines
While the P4529564 is for - 6 Quart, 3/8" Pipe for "B" Engines
What's the difference between the two?
Re: Oil Pans- What's correct? [Re: CompSyn] #1167047
02/02/12 10:49 AM
02/02/12 10:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where are you getting the 564 description from ? the 564 is the pickup for the 402 pan , I have purchased both of those pick ups about 4 years ago.
I only have a 2002 Mopar Performance catalog to go by and it doesn't say what pans they are for , I went out on a limb and bought them to find out .
Re: Oil Pans- What's correct? [Re: JohnRR] #1167048
02/02/12 04:20 PM
02/02/12 04:20 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I'm getting that description info from - www.monicattichrysler.com
I have a 2000 Mopar Performance catalog and am probably seeing the same information you're seeing in your 2002 catalog; a whole lot of nothing.
Monicatti could be confused as well, who knows?
If you've bought the 565 and have confirmed it to be the correct one, that's the one I'll go with.
Thanks again for the info,
Anthony
Re: Oil Pans- What's correct? [Re: CompSyn] #1167049
02/02/12 06:31 PM
02/02/12 06:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Anthony
I can confirm it sometime tonight , I still have the box it came in ... if I wanted to dig deeper I could probably find the Summit slip ...
