Oil Pans- What's correct?
#1167030
01/28/12 10:58 AM
01/28/12 10:58 AM
Posts: 765 SE Wisconsin, USA
RP's R/T's
SE Wisconsin, USA
I thought my car had the original Oil Pan, but it doesn't. It's a 70 E-body, 440 + 6. What are identifiers of the different years, capacities? What is the significance of the 3-digit number on them? Who makes the the best repro's? (I know I had seen someone at the Nats with them) What would I expect to pay for an good original?
Re: Oil Pans- What's correct?
[Re: RP's R/T's]
#1167031
01/28/12 11:19 AM
01/28/12 11:19 AM
Posts: 4,115 MD
floyd
MD
[Re: RP's R/T's]
#1167039
01/29/12 01:40 PM
01/29/12 01:40 PM
Posts: 75,074 U.S.S.A.
JohnRR
U.S.S.A.
Is this what is available from Mopar? Any modifications that need to be done to be accurate?
Yes and yes, paint it .
[Re: B5 Bee]
#1167040
01/31/12 06:41 PM
01/31/12 06:41 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Yes, no numbers on a '70-'71 440HP, 440-6 and Hemi pan. The pan holds 6 qts with filter. MP reproduction is nice, P4529884. Make sure you get the correct 3/8" strainer to go with it.
Will an original 383 402 oil pan 3/8" pick-up work on a MP Hemi oil pan?
[Re: CompSyn]
#1167041
02/01/12 11:28 AM
02/01/12 11:28 AM
JohnRR
U.S.S.A.
No , the hemi pan is deeper than the 402 pan. The 3/8" pickup can be bought new from MP , last time I bought it it ws not very expensive , cheapest source I found was Summit .
[Re: JohnRR]
#1167042
02/01/12 01:33 PM
02/01/12 01:33 PM
CompSyn
Pacific NW USA
Thanks, that's good to know. I've looked but haven't been able to find sold information on the MP pick-ups. What part number would I use for a 383 with Hemi pan and 3/8" sized pick-up?
[Re: CompSyn]
#1167043
02/01/12 01:43 PM
02/01/12 01:43 PM
JohnRR
U.S.S.A.
P4529565
[Re: 6bblgt]
#1167044
02/01/12 01:49 PM
02/01/12 01:49 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
In '70 & '71 - the HEMI, 440+6 & 440HP used the same (no number) oil pan in E and B-bodies.
The 402 pan was used in '69 on b-bodies (earlier also) with 383s, 440HP, & 440+6 - it remained in use for '70 & '71 on E and B-bodies with 383s.
You are correct. I forgot that they carried over the 402 for the 383
[Re: JohnRR]
#1167046
02/01/12 10:06 PM
02/01/12 10:06 PM
CompSyn
Pacific NW USA
P4529565
Okay, this is where I'm getting hung up.
The notes say the P4529565 is for - 6 Quart, 3/8" Pipe for "RB" Engines
While the P4529564 is for - 6 Quart, 3/8" Pipe for "B" Engines
What's the difference between the two?
[Re: JohnRR]
#1167048
02/02/12 04:20 PM
02/02/12 04:20 PM
CompSyn
Pacific NW USA
Where are you getting the 564 description from ? the 564 is the pickup for the 402 pan , I have purchased both of those pick ups about 4 years ago.
I only have a 2002 Mopar Performance catalog to go by and it doesn't say what pans they are for , I went out on a limb and bought them to find out .
I'm getting that description info from - www.monicattichrysler.com
I have a 2000 Mopar Performance catalog and am probably seeing the same information you're seeing in your 2002 catalog; a whole lot of nothing.
Monicatti could be confused as well, who knows?
If you've bought the 565 and have confirmed it to be the correct one, that's the one I'll go with.
Thanks again for the info,
Anthony
[Re: CompSyn]
#1167049
02/02/12 06:31 PM
02/02/12 06:31 PM
JohnRR
U.S.S.A.
Anthony
I can confirm it sometime tonight , I still have the box it came in ... if I wanted to dig deeper I could probably find the Summit slip ...
