1970 Torqueflite correct color #1167025
01/28/12 04:54 AM
01/28/12 04:54 AM
Pa.
Tek52 Offline OP
Tek52  Offline OP
Pa.
Hello Folks! Can you guys tell me, what is the correct, factory finish on a 440HP/Torqueflite setup? I've seen transmissions hemi orange, Chrysler blue(for the 2bbl cars), and natural--what's correct? If the trannies were sprayed-- was it completely, or partially? Were the engines natural, partially sprayed, or ? at assembly time? And, not to open the worm can, the engines.. what is painted engine color-and what is not engine color? And--in the Mopar hobby, is there a good, reference available, that shows all the detail stuff? I restored a 68 Road Runner back in about 1990, and I remember a terrific series in a Mopar magazine, showing all the utility colors, inspectors' paint daubs, all the odd underchassis markings...? Anything out there today? Thanks!!
Re: 1970 Torqueflite correct color [Re: Tek52] #1167026
01/28/12 05:00 AM
01/28/12 05:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Raw aluminum...
Re: 1970 Torqueflite correct color [Re: Tek52] #1167027
01/28/12 11:41 AM
01/28/12 11:41 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
bare aluminum case and extention hsg.
black phosphate bolts (all of them)
Brass cooling line fittings
clear zinc plated shift levers
clear zinc plated pressure port plugs
And I believe the pan itself was bare steel with some kind of rust preventive, just not real sure what.
Re: 1970 Torqueflite correct color [Re: gtx6970] #1167028
01/28/12 12:19 PM
01/28/12 12:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The kickdown lever was zinc also?
Re: 1970 Torqueflite correct color [Re: burdar] #1167029
01/28/12 08:04 PM
01/28/12 08:04 PM
It's a dry heat
It's a dry heat
Not 100% sure,,, but my gut says yes
