Re: 69 4 speed paint color
[Re: shamefulcuda]
#1165944
01/27/12 04:01 PM
01/27/12 04:01 PM
Thanks Scott, thats what I was worried about is leaving it untouched and it looking 'rusty'. I'll check into that paint your referring to.
RPM isnt a paint, it is a rust preventative. If your trans is black, scuff it with a scotch brite pad and paint it cast iron grey. That will look plenty good enough for a driver. To strip that black paint off and then RPM the entire trans case would take a long time.
If you are building an O.E.M show car use the RPM, if you are building a driver....just paint it cast iron grey.
[Re: ]
#1165945
01/27/12 04:47 PM
01/27/12 04:47 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
