OK -- Hemi weld up header experts wanted #1164805
01/25/12 10:41 PM
01/25/12 10:41 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Hey Ineed some input on headers. Iwould like a weld up kit and I have not found anyone who makes one for a hemi. What do you know about this. A friend of mine built some from a BB chevy kit for a tube car.
Re: OK -- Hemi weld up header experts wanted [Re: robnbird] #1164806
01/26/12 12:39 AM
01/26/12 12:39 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Check this out
Then just buy some bends and have at it or send them the pattern.
Re: OK -- Hemi weld up header experts wanted [Re: robnbird] #1164807
01/26/12 11:12 AM
01/26/12 11:12 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Stahl Headers will sell you a kit with flanges and bends,or a partially assebled kit that is tach welded and you do the final welding.
I would look there for starters,if he does not show what you are looking for,he will steer you in the right direction.
Keith
Re: OK -- Hemi weld up header experts wanted [Re: robnbird] #1164808
01/26/12 02:36 PM
01/26/12 02:36 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
It has been a long time, but I bought a kit from Rick Fuller @ R&R Chassis in Louisville. Also Known as "Performance Parts" Craig M. built the headers for me at R&R.
502-447-4881
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: OK -- Hemi weld up header experts wanted [Re: Hemi Allstate] #1164809
01/26/12 02:48 PM
01/26/12 02:48 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I know Hedman Headers sells a Hemi kit because I bought one about 7 years ago.......
If you can't handle the truth, you're living a lie.......
Re: OK -- Hemi weld up header experts wanted [Re: Hemi Allstate] #1164810
01/26/12 02:53 PM
01/26/12 02:53 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
thanks I will try him
Re: OK -- Hemi weld up header experts wanted [Re: Dunnuck Racing] #1164811
01/26/12 04:51 PM
01/26/12 04:51 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Keith
Yep give Stahl a call. I have built several sets of headers using his stuff. I always have him send me the flanges, collectors and what he calls a box of mistakes. It is basically a big b of rejected bends are cast aside during header production in their shop. There is nothing wrong with the bends, they are bends that were a few degrees off and did not fit in the jig so they couldn’t be used. They are cheaper than buying the U and J bends. there are enough bends in the box to build a complete set of headers. I have always had bends left over.
Re: OK -- Hemi weld up header experts wanted [Re: Dabee] #1164812
01/26/12 04:54 PM
01/26/12 04:54 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Here is another set I built using Stahl's a box of mistakes.
Re: OK -- Hemi weld up header experts wanted [Re: Dabee] #1164813
01/26/12 05:24 PM
01/26/12 05:24 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have done the BB Chevy kits and used Hemi flanges as well as the Hedman kits.Hedman gives you quite a selection of bends and their 3/8 flanges with a 3+ inch stub pipes give you an excellent starting point.You can buy complete slip on collecters and weld or bolt them on and make that part of header making easy.You won't find the mopar kits in Summits cataloge but have to talk to a saleperson.The flange kit is aprox.$175 and the tubing kit is aprox $275.It beats the heck out of a $1200 set of custom headers and most all shelf stock Hemi headers run $800 and up.TTI makes the best fitting shelf headers.
Re: OK -- Hemi weld up header experts wanted [Re: B G Racing] #1164814
01/26/12 05:42 PM
01/26/12 05:42 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Rob here is the set I have you can hve them cheap if you like. I know you tried to call me a couple of times and I was tied up. They are stainless.
Jimmy
Re: OK -- Hemi weld up header experts wanted [Re: blown572dart] #1164815
01/28/12 01:31 AM
01/28/12 01:31 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
Jimmy, you have a PM
Randy
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: OK -- Hemi weld up header experts wanted [Re: Rapid588] #1164816
01/28/12 01:58 AM
01/28/12 01:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy
I own those headers now.... if you want them let me
know... I'm sure we can work a deal
Re: OK -- Hemi weld up header experts wanted [Re: Rapid588] #1164817
01/28/12 03:41 AM
01/28/12 03:41 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
JXXXXy ..... Mike , you have a PM
Randy
Re: OK -- Hemi weld up header experts wanted [Re: Rapid588] #1164818
01/30/12 08:55 AM
01/30/12 08:55 AM
pa
572charger Offline
572charger  Offline
pa
ive got hooker 2 1/4 hemi headers made for a dart in on my charger !!!! they fit, other than 1 tube on each side that goes around the torsion bars had to be modifide to fit around because they are wider in a b body very easy to do only took about 5 hrs then i sent them out to be coated !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: OK -- Hemi weld up header experts wanted [Re: robnbird] #1164819
01/30/12 02:16 PM
01/30/12 02:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We use SPD for all the materials to build headers with. Not the cheapest but IMO the best products.
FWIW I have a set of Hemi headers for a strut front car I would let go cheap. They used to be in my Barracuda back when it had a Hemi.
Re: OK -- Hemi weld up header experts wanted [Re: Al_Alguire] #1164820
01/30/12 04:03 PM
01/30/12 04:03 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
what is the tube size and length plus the collector
