auto trans shifter question. please help. #1164558
01/25/12 03:08 PM
01/25/12 03:08 PM
Iowa
krusemachine Offline OP
Iowa
working on a 64 Fury. has push button transmission and someone put in a floor shifter and console. not sure what cable is in the car as I'm not incredibly knowledgeable about these earlier cars. I can't adjust enough to go into park. can this trans and this shifter work together? can this trans be "upgraded to floor shift" by adding correct valve body, or rooster comb, and or cable or some combination of parts? car belonged to a friend who passed away in an accident and his widow asked me to put the finishing touches on his project. it drives but have to start it in neutral and can't put in park. any info helps.
Re: auto trans shifter question. please help. [Re: krusemachine] #1164559
01/25/12 03:27 PM
01/25/12 03:27 PM
BA, OK
O
orangedustya Offline
O
BA, OK
Aftermarket shifters and cables take a different shift lever. I believe they are shorter. Take the cable out of the lever, manually put in park and then see where the cable hits on the lever. You might be able to drill another hole in the lever or find the correct lever.
Re: auto trans shifter question. please help. [Re: orangedustya] #1164560
01/25/12 04:18 PM
01/25/12 04:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Push button trans have two cables. I think one is for gears and the other operates park.
Re: auto trans shifter question. please help. [Re: stumpy] #1164561
01/25/12 05:48 PM
01/25/12 05:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I know my 64 New Yorker definatly had a seperate cable and a lever. I beleive the lever horizontal was under the buttons.
I have mechanical Aptitude.
I can screw up anything.
Re: auto trans shifter question. please help. [Re: orangedustya] #1164562
01/26/12 02:13 AM
01/26/12 02:13 AM
Iowa
Iowa
I think it is a stock mopar shifter of the 60's? it has two cables but the one for forward gears won't go far enough to let the other engage park. the eye of the cable hits the ferrel before the park cable has traveled far enough to engage park.
Re: auto trans shifter question. please help. [Re: krusemachine] #1164563
01/26/12 12:04 PM
01/26/12 12:04 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is puuting it in neutral befor applying the park cable?
Can you adjust it?
Re: auto trans shifter question. please help. [Re: bboogieart] #1164564
01/26/12 05:50 PM
01/26/12 05:50 PM
Iowa
Iowa
I can't get it to go far enough. the cable simply wont travel that far. it hits the cable housing before it gets far enough to push the park cable in. do I need a different cable or interna parts? I don't think this has the bump on the "rooster comb" or shift arm on the valve body to allow starting in park. can i get an aftermarket shifter for this tranny? it was origionally push button.
Re: auto trans shifter question. please help. [Re: krusemachine] #1164565
01/26/12 06:12 PM
01/26/12 06:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If a PB cable was installed on the console shifter the end of the inner cable is too long to work with the console shifter. The correct console shift cable housing allows the end of the inner cable to travel into it. In the pic below you can see the differnce in the inner cable ends. (PB is at the top)
Also, the console shifter won't work with a PB trans, the PB valve body doesn't have the extra notch for Park so the manual valve bottoms out just past Reverse.
Re: auto trans shifter question. please help. [Re: John_Kunkel] #1164566
01/26/12 08:56 PM
01/26/12 08:56 PM
Iowa
Iowa
Thanks for the pictures. Now, can I put a console valve body on this PB trans? seems like that would fix this whole situation. thanks for the replies. also I have a couple of cables. when i can get over there I'll see if one looks like that. would the column cars be similar? also, I think I saw a picture somewhere of a cable with some sort of spring loaded mechanism on the end I think to allow it to travel after the valve bottoms out. didn't make sense then but does now. anyone ever seen that or know who makes it?
Re: auto trans shifter question. please help. [Re: krusemachine] #1164567
01/27/12 03:26 PM
01/27/12 03:26 PM
Iowa
Iowa
just found this. picture at bottom makes me wonder if the valve body and cable can be changed or if I need the whole transmission.
http://www.1962to1965mopar.ornocar.com/transtech.html
Re: auto trans shifter question. please help. [Re: krusemachine] #1164568
01/27/12 03:43 PM
01/27/12 03:43 PM
The early, pre 1961, cast iron torquefyte used a different shifter cable than the later, 1962 and up cars did. There are three different versions of the shifter and park cables also, 1962,63 and 64 push button shifters, 1963(maybe, not sure if they where offered in 1963) 1964 and 1965 console shifters and the last one is the 1965 colum shifters The valve bodys, cables, rooster combs and manual valves all need to match the last thing is the cable adjustment, take the trans pan off and watch the cable ends engagement in the rooster comb, I adjust the cable so the pin on the end of the cable will drop into the hole in the rooster comb easily in all the forward gears and in neurtral One hole in the retainer ring adjsutment can make the difference between having it adjusted properly or off a tiny bit Them early cable shifter trannys are a challenge
Re: auto trans shifter question. please help. [Re: krusemachine] #1164569
01/27/12 04:49 PM
01/27/12 04:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the transmission end of the cables, the cable end on the left with the wide groove is the console/column type and it does allow a small amount of over-travel when shifted into Park.
All '62-'65 valve bodies will interchange, so matching the shifter to the transmission only involves a valve body change.
Re: auto trans shifter question. please help. [Re: John_Kunkel] #1164570
01/27/12 06:33 PM
01/27/12 06:33 PM
Iowa
Iowa
thanks everyone for all the great info so far? I'm learning about these great older mopars. I want to make this car user friendly for My buddies widow. anyone know where I can find the proper valve body at a good price? I have experience rebuilding GM transmissions so installation shouldn't be a problem.
Re: auto trans shifter question. please help. [Re: John_Kunkel] #1164571
01/27/12 07:52 PM
01/27/12 07:52 PM
John, I have found that there are at least two different female ends that hook onto the rooster comb, the later console/column shifter cables ends used on the early push button rooster combs will allow the trans to not be in the gear selected all the way, depending if up shifting or down shifting. This can be DANGEROUS as well as damage the trans when it is driven mall adjusted to make it work part way
Re: auto trans shifter question. please help. [Re: Cab_Burge] #1164572
01/28/12 04:32 PM
01/28/12 04:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, the adapter that connects the cable to the roostercomb is different, the console/column adapter attaches with an E-clip while the PB adapter attaches with a nut. The hole in the roostercomb is a different size, so the PB adapter can't be installed on a console/column roostercomb.
Re: auto trans shifter question. please help. [Re: John_Kunkel] #1164573
01/28/12 08:16 PM
01/28/12 08:16 PM
Iowa
Iowa
found this on E-Bay. looks like an option but not sure which valve body casting it is yet. Didn't bother to look when pan was off last summer. is it a major difference.
http://www.ebay.com/itm/220813125529?_tr...:IT&vxp=mtr
Re: auto trans shifter question. please help. [Re: krusemachine] #1164574
01/28/12 08:56 PM
01/28/12 08:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Regardless of what the seller says that kit will not convert a PB valve body to console...the PB casting doesn't have the needed hole to allow the manual valve to travel into the Park position.
Re: auto trans shifter question. please help. [Re: John_Kunkel] #1164575
01/30/12 11:23 AM
01/30/12 11:23 AM
Iowa
Iowa
Thanks. can I use a column cable on a floor shifter by removing the tab?
Re: auto trans shifter question. please help. [Re: krusemachine] #1164576
01/30/12 06:44 PM
01/30/12 06:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Column cables are much too short for console shifters.
Re: auto trans shifter question. please help. [Re: John_Kunkel] #1164577
01/31/12 05:19 AM
01/31/12 05:19 AM
Iowa
Iowa
Thanks for all the help. I think now I have a better idea what to look for and what to avoid. you've been great help thanks...Jason
