OEM rod bolts: are they good? Or is ARP superior? #1163628
01/23/12 07:51 PM
01/23/12 07:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I was wondering hows the quality of the bolts on a ser of lets say NOS LY rods.
I have NOS set of LY rods and I was wondering about the quality of the bolts that came on those from the factory. Are they good bolts? Comprable to something you can get from ARP nowadays?
How would those NOS rods with NOS bolts live in an old school street performace stock stroke 440 build?
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: domingo] #1163629
01/23/12 08:10 PM
01/23/12 08:10 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There is no comparison between the two types. The stock rod bolts are the weak link in the rod.
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: jbc426] #1163630
01/23/12 08:59 PM
01/23/12 08:59 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I was thinking the OEM bolts were OK, and that people just swapped em because they are no good to reuse and I guess you can get Ma Mopar OEM rod bolts anymore brand new.
After all, those were the rod bolts that came on 440-6 and HEMI cars, right?
Or did people back in the day when they raced the Max Wedges, race HEMIs, 440.6 A 12 package cars, etc changed the rod bolts over to ARPs or similar before they went out racing?
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: domingo] #1163631
01/23/12 10:19 PM
01/23/12 10:19 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
you had the rod bolt problem on another post. i dont know if this would make a difference but the torque on the arp is 60 foot pounds and stock rod bolts are 45.aftermarket rod bolts are worth it.
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: d-150] #1163632
01/23/12 10:29 PM
01/23/12 10:29 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
its 50 on the one im using....
I am inclined to toss these rods and use a NOS set of LYs I have here....but I was thinking of leaving the NOS rod bolts on and not bothering with the ARPs.
This is weirds I have used ARPs on stock rods on toher builds and never had this happen-
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: domingo] #1163633
01/23/12 11:28 PM
01/23/12 11:28 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
double check rod bearing size. i got bearings that were not right size crank was just polished standard clevite 77 bearings when i torqued just a couple motor would turn over.torqued them all down motor would not turn.took them back to napa put new set in and could turn crank by hand
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: domingo] #1163634
01/24/12 01:21 AM
01/24/12 01:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bad example except for the hemi rod which had a larger rod bolt.
The 6pk rod came about because the 69 A12 had problems breaking rods , the 6pk rod design was good till whomever designed it DROPPED THE BALL and left the 3/8 rod bolts in them instead of upsizing to 7/16 bolts like the Hemi rods had.
The stock rod bolts will be fine for a grocery getter with a 318 ...
Re: OEM rod bolts: are they good? Or is ARP superior? [Re: JohnRR] #1163635
01/24/12 01:40 AM
01/24/12 01:40 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Domingo...spend the "wise" money on a set of 7/16" ARP rod bolts! Money well spent..in my opinion! Definately BETTER than the factory rod bolts...and in the long run...SAFER!
