408 Hp/Tq #1163404
01/23/12 02:43 PM
01/23/12 02:43 PM
Illinois
bbach Offline OP
bbach  Offline OP
Illinois
Just built this engine for my duster wondering what you think?
408
forged icon pistons
scat rods
scat cast 4" crank
Hughes HER 4246 Hydraulic Roller
242/246 at.50 duration
.592/.606 with 1.6 roller rockers from Hughes
106 Lobe Sep
Edelbrock performer RPM heads super prepped by Hughes
11 to 1 compression
195 psi cyl pres
ported gasket matched Wieand Stealth
870 holley
TTI step headers
Main Girdle
Progear Roller Chain
Stock Mopar Distributor with Pertronix 2 and Fire Core Wires
Timing about 18 Initial, 34 Total
In a 3100 Lb duster
4-speed
3.91, 8 3/4
Re: 408 Hp/Tq [Re: bbach] #1163405
01/23/12 02:52 PM
01/23/12 02:52 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
Depending on the carb, and dyno and who is running it,
I'll guess 475/475
Karma has no menu. You get served what you deserve.
Re: 408 Hp/Tq [Re: bbach] #1163406
01/23/12 03:15 PM
01/23/12 03:15 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It better make 500+ tq.
Hp could be all over the map depending on how that intake reacts. Could be 475, could be 520
Fuel may be an issue if running pump gas.
Re: 408 Hp/Tq [Re: bbach] #1163407
01/23/12 07:19 PM
01/23/12 07:19 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
sounds good
Re: 408 Hp/Tq [Re: bbach] #1163408
01/24/12 12:10 AM
01/24/12 12:10 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
408
forged icon pistons
scat rods
scat cast 4" crank
106 Lobe Sep
11 to 1 compression
195 psi cyl pres
870 holley
TTI step headers
Main Girdle
In a 3100 Lb duster
4-speed
3.91, 8 3/4
I think it will make more power than that crank will handle. Shoulda used a forged steel crank. The motor in our dart is similar but We run the solid 276/280 AS cam and an M-1 intake,950 HP. We have ran 10.0s at 130 plus ,race weight 3130#
Steve
Re: 408 Hp/Tq [Re: WheelsUp73] #1163409
01/24/12 04:55 PM
01/24/12 04:55 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I think it could use a better intake, but my guess.
525HP & 500+ lb. tq.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 408 Hp/Tq [Re: joedust451] #1163410
01/24/12 07:27 PM
01/24/12 07:27 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'd run a Victor 340 on that one, similar build to my 414 except I run a vic, 1000hp and a 266/269 Solod roller, I figure mines around 550-ish, but it's hamstrung by the small headers that fit the chassis.
Not sure how a Hughes port job compares to my Shady Dell stage 2's but I'd guess 530-ish if your manifold doesn't choke her off too bad up top.
Pretty sure Bullet grinds the Hughes HRs, they make good broad power for sure!
WIZE
In Car:
Re: 408 Hp/Tq [Re: Streetwize] #1163411
01/24/12 09:24 PM
01/24/12 09:24 PM
Illinois
bbach Offline OP
bbach  Offline OP
Illinois
I stayed with the stealth cuz this is almost strictly street driven.
Those estimates are what I was thinking as well. I saw dyno results from a similar build with 10 degree less duration and 10 to 1 it was right at the 500hp mark.
