good ignition modules? #1162838
01/22/12 09:03 PM
01/22/12 09:03 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
It's time for a new ecu ignition module, i am trying to find a good module that will last a long time and be reliable and provide a good spark, with that being said should i get a borg warner select module or a napa echlin module or a car quest blue line module or a standard ignition module or a mopar orange ignition module? what modules have you guys had good luck with? and what would you guys reccomend? thanks.
Re: good ignition modules? [Re: pjc360] #1162839
01/23/12 01:06 AM
01/23/12 01:06 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mopar chrome box..
Was running an MSD 6, switched over to a Mopar chrome box runs smoother and easier starting..
Just my $0.02..
Re: good ignition modules? [Re: Sinitro] #1162840
01/23/12 01:25 AM
01/23/12 01:25 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
i thought the mopar chrome box was good thru for 8000rpm? I'm needing a new module for my truck, it has the mopar vaccume advanced electronic ignition, it very rarely see's anything over 4500 rpm, but ocasionally i get on her and get up to 6000 rpm. so would the orange box be more apropriate for what i'm doing? i have an orange module that i found on one of my shelves in the garage, but i do not know if it works... i'm going out of town tommarrow and i can pick up a borg warner select ignition module for 26.99 and the local napa at the little town im in now wanted 67 bucks for there echlin ignition module and car quest wanted 52.50 for there car quest blue line ignition module, and i am pretty sure that borg warner i can get for 26.99 is just as good as the napa echlin and the car quest blue. So i decided i will go ahead and buy the borg warner ignition module and when i get back i will try the orange mopar ignition module and if it works i'll return the borg warner, if it dont work i'll slap the borg warner on it, i have been told that borg warner makes real good ignition parts.
Re: good ignition modules? [Re: pjc360] #1162841
01/23/12 10:27 AM
01/23/12 10:27 AM
any ex the orange death. Get the cheapest one you can, carry a spare. The beef comes from your coil/ballast selection.
Re: good ignition modules? [Re: RapidRobert] #1162842
01/23/12 11:54 AM
01/23/12 11:54 AM
dogdays Offline
dogdays  Offline
Standard Ignition IIRC LX101 is the one recommended by Dr. Chris Jacobs years ago.
With the problems that have been associated with Chrome and later orange boxes I cannot see any point to buy one of them. If you have an orange box try it, it may work.
Otherwise I suggest you run the electronic distributor directly into an aftermarket multispark box. That way you can ditch the ballast resistor as well. You'll need a two conductor trailer connector which is the same size as the stock plug.
I'm doing this with an old Jacobs coil and an MSD 6A that I bought on the 'bay for $40. If you are buying fron scratch I suggest an Accel 300+ ignition box and coil, again I have bought a few on the 'bay with coil and wiring harness for top price of $120.00, new.
R.
Re: good ignition modules? [Re: dogdays] #1162843
01/23/12 04:33 PM
01/23/12 04:33 PM
P
Paul_Fancsali Offline
P
Get a new 4 -pin mopar elc module for 86-87 350 series truck or van Contrary to what you may read They will go to 6K easy and not miss a beat. Frankly I would put in a pertronix easy and reliable
Re: good ignition modules? [Re: Paul_Fancsali] #1162844
01/25/12 03:49 AM
01/25/12 03:49 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
So the orange mopar ignition module is not good? or it is good? alot of people have told me its a great module reliable and consistent? thats the module i think i'm going to run, unless somone says other wise?
Re: good ignition modules? [Re: pjc360] #1162845
01/25/12 11:06 AM
01/25/12 11:06 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
They WERE good. Nowdays even the chromed are coming bad.
Its about durability. as far they keep working they are great! really!. The problem is the don't last long a lot latelly... even the chromed ones ( I have got two chromed failed in two years )
If you have luck, will be great. Its a random stuff LOL
Re: good ignition modules? [Re: pjc360] #1162846
01/25/12 11:28 AM
01/25/12 11:28 AM
Not good, do not waste your money, many many reported failures (missing at speed etc)
Re: good ignition modules? [Re: NachoRT74] #1162847
01/25/12 11:52 AM
01/25/12 11:52 AM
NY usa
540challenger Offline
NY usa
this is the first time i have heard of a chrome box going bad so quick. Has anyone else had a problem iwth a crhome box i got mine about 5-6 years ago and its still going. When did you purchase yours???
Re: good ignition modules? [Re: pjc360] #1162848
01/25/12 12:27 PM
01/25/12 12:27 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
The history of the orange and silver box's has been in question for some time, especially the new ones.
Then we have the FBO ECU which is currently in a re-design phase and won't be available until at least March. Then we have the Rev-n-nator ECU which is currently being tested.
The above are reasons why I decided to try the MSD Street Fire box to replace my existing ECU. I feel that there is a market for this type of box (MSD, Mallory, etc.) due to the above issues with the Chrysler style ECU's on the market today. These boxes can be used with stock coils and stock distributors and they appear to be fairly dependable, which is what I have not had from the Chrysler style ECU's that I have used.
I am not convinced that there is a "GOOD" ECU on the market
(Note: two of the above mentioned are not on the market as of today.).
I think that it is a hit or miss just like allot of aftermarket electronics that are being sold these days. I would suggest that if you want the stock appearing ECU to try a local parts store house brand and carry a spare. If you are not into the stock appearance, then try one of the major brand ignition companies for one of their boxes.
Re: good ignition modules? [Re: 540challenger] #1162849
01/25/12 04:08 PM
01/25/12 04:08 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well dunno the dates certainly since they were bought from another guys around, one of them still packaged, but I can tell for sure one is with the old stilish PN and penstastar badly printed and the other one with the newer Mopar performance good and clean printed design
Re: good ignition modules? [Re: NachoRT74] #1162850
01/25/12 10:25 PM
01/25/12 10:25 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
so what about the standard x-series module? that seems to be the module that everyone has reccomended ether that or the orange or chrome boxes. i think i might as well order the standard x-series module, alot of people have told me its goo till 6500-7000 rpm. one guy i know told me he runs that on his car thats running a 10.5 qaurter mile at 125 mph, he said that standard x-series has never let him down and that it nevers misses a beat.
Re: good ignition modules? [Re: pjc360] #1162851
01/26/12 01:33 AM
01/26/12 01:33 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I am running one of the ones Rick Ehrenbergh ( sp? ) sells by $40 on the ebay, suposeelly outperforms the orange box and is close to the chromed box. Its working really nice without miss a beat, although actually I liked more the FBO A688 UNTILL BROKE DOWN ( just 4 months RUNNING even 20 months mounted ). It had better start up too.
the old FBO A688 has been the best I have used, including the chromed MP ones... BUT...
Re: good ignition modules? [Re: 540challenger] #1162852
01/26/12 02:47 AM
01/26/12 02:47 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I've never had any troubles with MP chrome boxes, run them on everything- even my motorhomes.
Never had any problem with orange boxes until about ten years ago. Never had a "high speed miss" of any sort, but I have had half a dozen orange boxes bought within the last ten years have the "hard/no hot restart". Starts cold (USUALLY) but will crank and crank hot, trying to start ONLY when you release the key.
I have a near new orange box with the restart issue sitting under the seat of my 73 motorhome, it worked for about ONE WEEK!
I have an FBO A688 in my Jensen, it's been close to two years and it sure runs strong.
CrAzYMoPaRGuY
Re: good ignition modules? [Re: CrAzYMoPaRGuY] #1162853
01/26/12 04:06 AM
01/26/12 04:06 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The "hard/no hot restart. Starts cold" is a grounding problem, not the box. Run a ground directly from the box case to the engine block.
Re: good ignition modules? [Re: 451Mopar] #1162854
01/26/12 04:13 AM
01/26/12 04:13 AM
Canada
Canada
Nope, it's orange boxes. My motorhomes have separate grounds to the box already.
CrAzYMoPaRGuY
Re: good ignition modules? [Re: 451Mopar] #1162855
01/26/12 10:18 AM
01/26/12 10:18 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
sometimes, yes, but when you have a direct AUXILIARY WIRE getting to the module to be able to restart it and even in that way, hard to restart it, it must be something else
Re: good ignition modules? [Re: NachoRT74] #1162856
01/26/12 03:32 PM
01/26/12 03:32 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
So running an extra ground wire from the ignition module helps? does it have to be grounded to the engine? or can i ground it off the firewall right next to it?
Re: good ignition modules? [Re: pjc360] #1162857
01/26/12 04:08 PM
01/26/12 04:08 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Well- Might get lynched for this but-
When I stripped the Lean Burn system off my 82 New Yorker I replaced the ignition module by converting to a GM aftermarket HEI module.
Cheap as death (modules are $15-30), available literally EVERYWHERE, and give a good and hot spark. Car starts easier, runs better and gives me better milage.
Read about it here first:
http://www.dippy.org/forum2/index.php?topic=2849.msg33339#msg33339
and here:
http://www.slantsix.org/forum/viewtopic.php?t=15779
If I could afford it, I'd probably run an MSD-6 unit for the same reasons, but I'm dirt-poor, so this is what I did.
Good Luck with it,
CC.
