Re: good ignition modules?
[Re: pjc360]
#1162839
01/23/12 01:06 AM
01/23/12 01:06 AM
Posts: 5,439 So Cal
Sinitro
So Cal
Mopar chrome box.. Was running an MSD 6, switched over to a Mopar chrome box runs smoother and easier starting.. Just my $0.02..
[Re: RapidRobert]
#1162842
01/23/12 11:54 AM
01/23/12 11:54 AM
dogdays
Standard Ignition IIRC LX101 is the one recommended by Dr. Chris Jacobs years ago. With the problems that have been associated with Chrome and later orange boxes I cannot see any point to buy one of them. If you have an orange box try it, it may work.
Otherwise I suggest you run the electronic distributor directly into an aftermarket multispark box. That way you can ditch the ballast resistor as well. You'll need a two conductor trailer connector which is the same size as the stock plug.
I'm doing this with an old Jacobs coil and an MSD 6A that I bought on the 'bay for $40. If you are buying fron scratch I suggest an Accel 300+ ignition box and coil, again I have bought a few on the 'bay with coil and wiring harness for top price of $120.00, new.
R.
[Re: pjc360]
#1162845
01/25/12 11:06 AM
01/25/12 11:06 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
They WERE good. Nowdays even the chromed are coming bad.
Its about durability. as far they keep working they are great! really!. The problem is the don't last long a lot latelly... even the chromed ones ( I have got two chromed failed in two years )
If you have luck, will be great. Its a random stuff LOL
[Re: NachoRT74]
#1162847
01/25/12 11:52 AM
01/25/12 11:52 AM
Posts: 2,826 NY usa
540challenger
NY usa
this is the first time i have heard of a chrome box going bad so quick. Has anyone else had a problem iwth a crhome box i got mine about 5-6 years ago and its still going. When did you purchase yours???
[Re: pjc360]
#1162848
01/25/12 12:27 PM
01/25/12 12:27 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
The history of the orange and silver box's has been in question for some time, especially the new ones. Then we have the FBO ECU which is currently in a re-design phase and won't be available until at least March. Then we have the Rev-n-nator ECU which is currently being tested.
The above are reasons why I decided to try the MSD Street Fire box to replace my existing ECU. I feel that there is a market for this type of box (MSD, Mallory, etc.) due to the above issues with the Chrysler style ECU's on the market today. These boxes can be used with stock coils and stock distributors and they appear to be fairly dependable, which is what I have not had from the Chrysler style ECU's that I have used.
I am not convinced that there is a "GOOD" ECU on the market (Note: two of the above mentioned are not on the market as of today.). I think that it is a hit or miss just like allot of aftermarket electronics that are being sold these days. I would suggest that if you want the stock appearing ECU to try a local parts store house brand and carry a spare. If you are not into the stock appearance, then try one of the major brand ignition companies for one of their boxes.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: pjc360]
#1162851
01/26/12 01:33 AM
01/26/12 01:33 AM
NachoRT74
Valencia, España
I am running one of the ones Rick Ehrenbergh ( sp? ) sells by $40 on the ebay, suposeelly outperforms the orange box and is close to the chromed box. Its working really nice without miss a beat, although actually I liked more the FBO A688 UNTILL BROKE DOWN ( just 4 months RUNNING even 20 months mounted ). It had better start up too.
the old FBO A688 has been the best I have used, including the chromed MP ones... BUT...
[Re: CrAzYMoPaRGuY]
#1162853
01/26/12 04:06 AM
01/26/12 04:06 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Never had a "high speed miss" of any sort, but I have had half a dozen orange boxes bought within the last ten years have the "hard/no hot restart". Starts cold (USUALLY) but will crank and crank hot, trying to start ONLY when you release the key.
The "hard/no hot restart. Starts cold" is a grounding problem, not the box. Run a ground directly from the box case to the engine block.
[Re: 451Mopar]
#1162855
01/26/12 10:18 AM
01/26/12 10:18 AM
NachoRT74
Valencia, España
sometimes, yes, but when you have a direct AUXILIARY WIRE getting to the module to be able to restart it and even in that way, hard to restart it, it must be something else
