when is a torque strap necessary? #1162658
01/22/12 04:19 PM
01/22/12 04:19 PM
central new york
pettyblue440 Offline OP
central new york
what hp or et does a torque strap make a difference? carin question is a 450 hp b body with auto and stock tires. thanks, jon
Re: when is a torque strap necessary? [Re: pettyblue440] #1162659
01/22/12 04:56 PM
01/22/12 04:56 PM
Locomotion Offline
Locomotion  Offline
Basically, any time you put the pedal to the floor regardless of engine. OEM rubber eventually pounds out and the replacement rubber can only be worse. Depending on what k-member you have, poly spool mounts or Magnum Mounts (or something like that (sandwich style), would work well. But adding a strap is never a bad idea.
Re: when is a torque strap necessary? [Re: Locomotion] #1162660
01/22/12 09:45 PM
01/22/12 09:45 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
moreso when it's as footbraker
home of the
Sox and Martin Hemi Duster
Re: when is a torque strap necessary? [Re: HEMIFRED] #1162661
01/22/12 10:25 PM
01/22/12 10:25 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
It my 73, which is just a little 500hp small block, we are constantly breaking the drivers side motor mount.. I would guess at least 1 per year with the amount we street drive and race...
I've made a little torque strap using a hardware store turnbuckle set up and the motor mounts no longer breaks..
Re: when is a torque strap necessary? [Re: HEMIFRED] #1162662
01/22/12 10:31 PM
01/22/12 10:31 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Somebody around here told me to try a solid on the driver's side and rubber on the passenger that way the solid takes up the shock but the rubber keeps it from vibrating the whole car. Worked OK in the last street car I had set up that way.
Everybody makes fun of a hillbilly until they need something fixed
Re: when is a torque strap necessary? [Re: B_Body_Bob] #1162663
01/22/12 10:59 PM
01/22/12 10:59 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I made my driver's side motor mount into a semi-solid but drilling through it and putting in some grade eight bolts and nuts. It can compress a little but it can't go the other way from engine torque. That's the idea anyway.
Re: when is a torque strap necessary? [Re: 67Satty] #1162664
01/22/12 11:14 PM
01/22/12 11:14 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i think a strap is always necessary whenever your not worried about the looks of the engine compartment. this is my design and its hidden pretty well by the battery and tray. now obviously it doesn't work with power steering but gives you an idea. I don't like mounting off the boss on the front of block as it "could" cause distortion in that cylinder, both of these cars have stock rubber mounts. been like this for 5-6 years now and no trouble
here it is in my 68 b-body
Re: when is a torque strap necessary? [Re: prochargedhemi] #1162665
01/22/12 11:27 PM
01/22/12 11:27 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
where can someone get a strap like that one ?
very nice !
1.39 9.85 - 137 mph
Re: when is a torque strap necessary? [Re: Ari440] #1162666
01/23/12 12:09 AM
01/23/12 12:09 AM
Temperance, MI
P
P
Temperance, MI
i made those ones. its pretty basic really. a couple heim ends, some aluminum bar stock/steel stock or tube, and 8 inches of 1/4x2 plate. obviously you will need someone to drill/tap the rods left and right hand to thread the heims into but other than that its DIY stuff
Re: when is a torque strap necessary? [Re: pettyblue440] #1162667
01/23/12 01:41 AM
01/23/12 01:41 AM
NY
B1duster Offline
B1duster  Offline
NY
A piece of chain with a little slack from a motor mount block bolt to the K frame works great. Went 9s with rubber mounts.
Re: when is a torque strap necessary? *DELETED* [Re: prochargedhemi] #1162668
01/23/12 01:44 AM
01/23/12 01:44 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Post deleted by polyspheric
Boffin Emeritus
Re: when is a torque strap necessary? [Re: polyspheric] #1162669
01/23/12 12:50 PM
01/23/12 12:50 PM
Temperance, MI
P
P
Temperance, MI
Sorry, not trying to be Mr. Wizard here, but this needs to be said.
The quality of the parts and the installation is not possible to evaluate from here, let's agree that they were well chosen and have held up well.
What I find troubling is the position of the mounts.
The only resistance it offers to forward and back motion is the angle built into the Heim joints - and they're not designed to take any thrust that way. If you had significant motion (another mount fails, etc.) the Heims would go out of range and fail.
Vertical movement of the block is zero, since the 2 links form a triangle. If either link were removed, or both links mounted at different heights separately, the block could rise and fall with some side motion. It would resist rotation (torquing) but not efficiently.
Side to side movement of the block is zero. If it tried to go right, the links are in tension - good, no harm. If it tries to go left, at least 1 link is in compression and will bend.
The only block motion that is both controlled and safe now is an angle rotating the entire block around the fender mount. This is opposite the way the block will move under power.
In short, the hardware is fine, but the relationships are not helping you.
In order to resist engine rotation, the link must always be in tension (pulling down on the left side, or up on the right), never at 90° to the expected force.
Its worked fine for my 790hp rig. Ive seen faster cars with less. if you don't like it don't use it, it was posted for an example.
Re: when is a torque strap necessary? [Re: polyspheric] #1162670
01/23/12 01:09 PM
01/23/12 01:09 PM
organ
maximum entropy Offline
organ
you said what i was thinking. the rod should be tangential to the crank axis. i'm sure it works, but that doesn't make it optimal. i had a solid strap running down the the driver's side to the k member, rubber on the passenger side. it took me about a half an hour to fab up, and worked great.
Re: when is a torque strap necessary? [Re: maximum entropy] #1162671
01/23/12 01:27 PM
01/23/12 01:27 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Here's a link to making the rubber insulator into a semi-solid mount:
http://www.dodgecharger.com/forum/index.php?topic=13216.0;all
Re: when is a torque strap necessary? [Re: 67Satty] #1162672
01/23/12 05:30 PM
01/23/12 05:30 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
for years only a chain was attached whick allow a certain degree of movement and luxury of the rubber mounts . when the motor starts to move to far the chain stops it all.
that might be to simple for many here but it works 100%
home of the
Re: when is a torque strap necessary? [Re: HEMIFRED] #1162673
01/23/12 08:19 PM
01/23/12 08:19 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
that's what i use, a chain from my sway bar bracket to the boss on the front of the block, works great because you still have the 2 rubber mounts but there's no way the engine can break loose. that is a good point about the cylinder distortion though, i may change to the upper water pump bolt hole. cheap and easy and quite necessary on any 440 in my opinion. when i bought my 70 coronet in 2001 it had a really tired 440 AND a busted drivers side mount.
Re: when is a torque strap necessary? [Re: dirtybee] #1162674
01/24/12 01:48 AM
01/24/12 01:48 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I cut a chain link in half, welded it to the K member, then run a turnbuckle up to the block from there. Simple design, easy to do, cheap.
Re: when is a torque strap necessary? [Re: prochargedhemi] #1162675
01/24/12 02:13 AM
01/24/12 02:13 AM
New York
polyspheric Offline
polyspheric  Offline
New York
This is the point where I mention that whenever some expert (and he must be an expert - he's got 790 hp) takes a technical comment as a personal insult, my interest in assisting anyone goes down 1 notch.
I've seen faster cars with less upside down, too.
Boffin Emeritus
Re: when is a torque strap necessary? [Re: polyspheric] #1162676
01/24/12 07:34 AM
01/24/12 07:34 AM
Temperance, MI
P
P
Temperance, MI
i never claimed to be an expert. It worked for me, like i stated. It is shown for example, as stated. I didn't take it personally at first but by the looks of it you are trying to take it in that direction. Enjoy
Re: when is a torque strap necessary? [Re: prochargedhemi] #1162677
01/24/12 08:54 AM
01/24/12 08:54 AM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
Why is everyone busting his sack?!?! He posted an example that has worked for him. As stated, if you don't like it, don't use it!
