Re: Tore into the engine tonight....
[Re: dartman366]
#1162298
01/21/12 11:46 PM
01/21/12 11:46 PM
Posts: 3,456 Out West
408strokerdart
Out West
Check that the ball end on the pushrod and the lifter/rocker adjuster to make sure the radius matches and also check that the adjuster hasn't pushed the threads in the rocker.
Will take a good look at those items tomorrow.
[Re: 00snake530]
#1162301
01/22/12 12:00 AM
01/22/12 12:00 AM
408strokerdart
Out West
last time i had a loose rocker like that the cam lobe went flat
Cam is getting re-ground anyway...
[Re: supercomp]
#1162302
01/22/12 12:01 AM
01/22/12 12:01 AM
408strokerdart
Out West
Do you run rollers?
Yes. Crane ultra pro.
[Re: 408strokerdart]
#1162305
01/22/12 10:26 AM
01/22/12 10:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Brian I forget what rockers you are running but some of the adjusters are junk and will pull the threads out and were soft so the push rods beat the cups... also as said check the dia of the cup to the PR ball... 3/8 balls DONT FIT on any of the cups
[Re: MR_P_BODY]
#1162306
01/22/12 10:31 AM
01/22/12 10:31 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Can't believe it ran as well as it did. As mentioned before, you're going to Pick up substantial gains.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#1162307
01/22/12 10:36 AM
01/22/12 10:36 AM
MR_P_BODY
I really doubt it will pick up much at all... JMO
[Re: MR_P_BODY]
#1162308
01/22/12 11:11 AM
01/22/12 11:11 AM
dartman366
Mt. Vernon, Ohio
I agree,,if it picks up at all it will be negligable.
[Re: hemi-itis]
#1162312
01/22/12 01:07 PM
01/22/12 01:07 PM
MR_P_BODY
How could it NOT pick up when these issues are corrected???
If he were to just correct the problem it wouldnt change much at all... I've been there... but he is regrinding the cam so we wont know for sure
[Re: Ari440]
#1162315
01/22/12 02:13 PM
01/22/12 02:13 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Sounds like it is time to junk it and get something with more power Seriously as has been said already check everything over very well. Leave no stone unturned..
