Charging to much! #1162169
01/21/12 06:59 PM
01/21/12 06:59 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Well had to go to the JY to get parts for the DD so had to drive the duster. On way home (about 40 miles) started smelling sulfer? Any way when I got home poped hood and my red top Optima was smoking. Case was real hot and the alternator felt hot to. Felt the voltage regulator and it was cold. So after I let it cool down I checked the battery voltage and it was 12.9vdc so I started it and it was 13.4 at Idle and 14 reved up. I unpluged the VR and it made no diffrence so then I unplugged one field wire at a time and on the second wire it finally quit charging. Any way I would like to figure out what failed> I would have guessed the VR but after my expiriment I'm thinking the alternator is bad. Please someone educate me on how a stock 70's alternator can over charge or am I just overthinking this and the VR is bad.
Re: Charging to much! [Re: mod5v] #1162170
01/21/12 07:14 PM
01/21/12 07:14 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
14.00 volts is not overcharging. 14.99 is...
Re: Charging to much! [Re: mod5v] #1162171
01/21/12 07:17 PM
01/21/12 07:17 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought that this was another topic about paint jobs.......
Re: Charging to much! [Re: Pacnorthcuda] #1162172
01/21/12 07:23 PM
01/21/12 07:23 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
I understand that but what is causeing my battery to get so hot its smokin?
Re: Charging to much! [Re: mod5v] #1162173
01/21/12 07:42 PM
01/21/12 07:42 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Smoking? 14.0 is not over charging, and agreed that 15 plus is. Are you running a volt meter or an amp meter? Are the lights too bright? If you were over charging then one of the fields on the alt could be bad and cause this.
Re: Charging to much! [Re: mod5v] #1162174
01/21/12 07:42 PM
01/21/12 07:42 PM
It may be overcharging during a condition you have not replicated during your VOM test. Is the alternator hot? Are all other electrical draws working ok?--Lights?
Re: Charging to much! [Re: Pacnorthcuda] #1162175
01/21/12 09:36 PM
01/21/12 09:36 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
50 deg sunny north texas day. had the radio playing didn't notice any problem there. YES the alternator was very hot. the Voltage reg was cold and the sealed gell cell battery was steaming out the vent holes. went about 100 miles round trip with the last 40 in one leg no stops. Noticed a smell when I got home poped the hood and saw battery "smokeing". I guess I'll just change out the VR and see if I have the problem come back.
Re: Charging to much! [Re: mod5v] #1162176
01/21/12 10:16 PM
01/21/12 10:16 PM
unplugging 1 field wire will disable the alt so for both to need to be unplugged it's shorted inside. Check both brushes/holders then mark the alt case so you can easily reclock it to the same position on reassembly & open it up & see what you see. Check rotor continuity to ground/any obvious improper grounds
Re: Charging to much! [Re: DANA60] #1162177
01/21/12 11:38 PM
01/21/12 11:38 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I had this happen exactly. The poreclain thread/fitting had a slight crack in it and caused my alt to over charge - saw the numbers on my voltmeter jump up to nearly 17!!! Pulled it apart, found a hairline crack in the threads. Replaced it, never happened again. Hope that helps.
Re: Charging to much! [Re: 67dodge67] #1162178
01/22/12 11:12 AM
01/22/12 11:12 AM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Thanks finally some real ideas on what to look for. The alternator is only 3 years old with maybe 3k on it so I think it had a limited life time warrenty. I will check and just get it replaced.
Re: Charging to much! [Re: mod5v] #1162179
01/22/12 11:43 AM
01/22/12 11:43 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Check your VR for good ground. Also, a shorted cell in the battery can cause high charging voltage.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Charging to much! [Re: 471Magnum] #1162180
01/22/12 12:11 PM
01/22/12 12:11 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
I had the same problem on my 74 charger. Everything was new as I had just finished the resto. Replacing the voltage regulator fixed it. I also re-sanded and tighted every ground under the hood. It's possible that an intermittent ground killed my regulator even though all of the connections looked good.
Re: Charging to much! [Re: mod5v] #1162181
01/22/12 12:13 PM
01/22/12 12:13 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
There's also the possibility that the battery has a simple shorted cell.
Rick E.
Re: Charging to much! [Re: 471Magnum] #1162182
01/22/12 12:15 PM
01/22/12 12:15 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
(quote)I unpluged the VR and it made no diffrence so then I unplugged one field wire at a time and on the second wire it finally quit charging.
Just wondering why you kept going back to the voltage regulator after this.
I have mechanical Aptitude.
I can screw up anything.
Re: Charging to much! [Re: Rick_Ehrenberg] #1162183
01/22/12 09:44 PM
01/22/12 09:44 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Rick E.
My vote also. The voltage you read across the battery is too low for a recently over charged battery unless a cell has shorted out.
Re: Charging to much! [Re: denfireguy] #1162184
01/22/12 11:52 PM
01/22/12 11:52 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
I've had a couple of people say shorted cell in battery. Never had one go like this before but theres always a first. I will wait a few days and check the battery voltage if its under 12 volts I'll pull it and take it in for a load test. I have checked all the grounds and they are clean and solid. I bypassed the amp guage a few years ago and have a 10ga wire directly from the alternator to the battery so that held up well. I'm thinking of putting a inline fuse or breaker in the circut tho.
