Smoking? 14.0 is not over charging, and agreed that 15 plus is. Are you running a volt meter or an amp meter? Are the lights too bright? If you were over charging then one of the fields on the alt could be bad and cause this.
I had this happen exactly. The poreclain thread/fitting had a slight crack in it and caused my alt to over charge - saw the numbers on my voltmeter jump up to nearly 17!!! Pulled it apart, found a hairline crack in the threads. Replaced it, never happened again. Hope that helps.
