Indy Valley Cover? #1161998
01/21/12 02:27 PM
01/21/12 02:27 PM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Does Indys Cast Aluminum Valley Cover work with Edelbrock/Stealth heads?
Re: Indy Valley Cover? [Re: Azzkikrcuda] #1161999
01/21/12 02:59 PM
01/21/12 02:59 PM
Not really, there around 1/4 to 3/8 inch clearance between the edge of the plate and the heads Those heads do not have the bottom of the heads machined to seal to that plate and they don't stick out far enough to slide a plate under them like the Indy heads do to seal them up I just thought of something else, if yuor building a low deck motor the RB(440) plate might work if your willing and able to work on it to make it work Lets us knwo what you end up doing and the results
Re: Indy Valley Cover? [Re: Cab_Burge] #1162000
01/21/12 05:29 PM
01/21/12 05:29 PM
North Dakota
North Dakota
This is on a 440.
Re: Indy Valley Cover? [Re: Azzkikrcuda] #1162001
01/22/12 12:17 PM
01/22/12 12:17 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Yes I've used an Indy valley plate on my 400 with Eddy heads
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
