A-body 8.75 with /6 #1161884
01/21/12 10:10 AM
01/21/12 10:10 AM
Western Colorado High Desert
moparmarks Online penguin-006 OP
moparmarks  Online Penguin-006 OP
You fellow junk yard dogs need to be checking the rears on all the A-bodies you find. Even /6 cars.
Just picked up this 71 Dart /6 3-sp w/ disc and 8.75
A friend has a 72 Duster that he bought from the original owner. /6 auto w disc and 8.75
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: A-body 8.75 with /6 [Re: moparmarks] #1161885
01/21/12 10:11 AM
01/21/12 10:11 AM
Looks original to me
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A-body 8.75 with /6 [Re: moparmarks] #1161886
01/21/12 10:13 AM
01/21/12 10:13 AM
Heres another 71 Dart /6. About the only thing missing is the rear end. Hmmmmmmm.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A-body 8.75 with /6 [Re: moparmarks] #1161887
01/21/12 10:36 AM
01/21/12 10:36 AM
Good for you, sometimes Lady Luck comes our way, makes up for the occaisional mishap/misfortune. I imagine Ma used what she had on hand if an item/inventory came up short as stopping the line was the last thing a foreman wanted to have happen on his shift
Re: A-body 8.75 with /6 [Re: RapidRobert] #1161888
01/21/12 11:47 AM
01/21/12 11:47 AM
indiana
generallee6901 Offline
indiana
I have a friend that used to own a 72 Duster with /6 and it had the 8.75 and disc brakes also.We thought it was kind of weird at the time.
Re: A-body 8.75 with /6 [Re: generallee6901] #1161889
01/21/12 01:10 PM
01/21/12 01:10 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
when mopar decides to drop a line they empty out the warehouse of leftovers, an old mopar friend/fiend told me they dumped 426 wedge motors that wouldnt sell (because of the hemi) they restamped the blocks 413 and threw them into newports--he told me to look at the casting marks because those werent changed----at the pickapart i picked up a dana 60 with a pinion snubber under a 72 D200---needless to say i took it home for $90 cut off the flanges/welded on 8.75 axle ends--installed truck 30" axles (8.75) and i had an E body setup------but then my son nabbed it to put under his 70 cuda---damn----the same friend also told me to check close on the 6cyl 3speed A bodies for these 8.75---bob
Re: A-body 8.75 with /6 [Re: moparmarks] #1161890
01/21/12 02:55 PM
01/21/12 02:55 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
not uncommon at all.. have seen quite a few of them. even saw a friends 4 door, had 8 3/4 front disc brake and front sway bar.
just parted this one out a few years ago. six cyl, front disc brake, and 8 3/4. also had a rim blow wheel..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: A-body 8.75 with /6 [Re: abodyjoe] #1161891
01/21/12 03:51 PM
01/21/12 03:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 70 dart I have for sale is an 8.75 /6 disc brake car 3spd. My 70 duster (also for sale) is an 8.75 318 auto car
Re: A-body 8.75 with /6 [Re: abodyjoe] #1161892
01/21/12 03:54 PM
01/21/12 03:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 8.75 axle was part of the HD towing package. It was available even on slant six cars.
Re: A-body 8.75 with /6 [Re: Kern Dog] #1161893
01/21/12 03:57 PM
01/21/12 03:57 PM
Kirkland, Washington
Pacnorthcuda Offline
and yet a 77 318 Volare I used to own came with a 7.25. Yea, it broke. Sometimes mopar did some weird things.
Re: A-body 8.75 with /6 [Re: moparmarks] #1161894
01/21/12 04:13 PM
01/21/12 04:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think the manual trans even in /6 tended to get the bigger rear end after 1970. Maybe something to do with the weight of the cars getting more and more as time went on. And/or warranty claims on 7.25 rears.
It seems a lot of these /6 and 318 1970 to 1972 Abodies with 8 3/4 tend to be sort of loaded (weight). A lot seem to have that option package that included the rim blow steering wheel. 8 3/4 and rim blow wheels seem to pair up often. And most of those also have A/C.
I don't think they were dumping this rear end in 70 and 71. I can sort of see late 1972. But Mopar didn't carry a complete 1 year inventory on rear ends.
Re: A-body 8.75 with /6 [Re: autoxcuda] #1161895
01/21/12 04:24 PM
01/21/12 04:24 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Either the 7.25 was upgraded over the years or something is wierd. I have seen several LOADED 73-76 slant six 4 door Valiants and Darts with the 7.25 axle. They theoretically should have had the 8.25 if durability was a concern. I stick with the towing package theory. HD axle, Trans cooler in HD radiator and 7 blade fan with fan clutch.
Re: A-body 8.75 with /6 [Re: Kern Dog] #1161896
01/21/12 04:31 PM
01/21/12 04:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Oh I agree. The later cars seem skimpy with the 8 1/4" rear. Although I do know of a 74 Dart Sport convertiple with /6 manual trans and 8 1/4". I'm thinking the manual trans did it.
But I don't think all those car we're finding the rear ends have trailer towing. MoparMarks, does the fender tag on those cars show trailer towing? Is trailer towing even on the fender tag?
Now IIRC, disk brakes automatically got you HD suspension.
Re: A-body 8.75 with /6 [Re: autoxcuda] #1161897
01/21/12 04:33 PM
01/21/12 04:33 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Ah... disc brakes! THAT makes sense too......
Re: A-body 8.75 with /6 [Re: Kern Dog] #1161898
01/21/12 04:52 PM
01/21/12 04:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Of the 5 cars mentioned on this thread with 8 3/4 rears, 5 had disc brakes.
This one didn't mention what brakes it had?:
This one is not certain what rear end it had originally. -but note it did have A/C, 318, vinyl top and the bigger looking front drums-
Re: A-body 8.75 with /6 [Re: moparmarks] #1161899
01/22/12 12:26 AM
01/22/12 12:26 AM
New Brunswick Canada
copperSwinger Offline
my 71 swinger 318 had a 8.75. drums no a/c no towing package no sway bar
Re: A-body 8.75 with /6 [Re: copperSwinger] #1161900
01/22/12 12:21 PM
01/22/12 12:21 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I would guess you got it when you spec'ed disc or 10" drums. I've never seen any 10" drums for small bolt pattern 7-1/4" rears.
In '73 they started using the 10" drums on BBP 7-1/4" with the BBP disc.
Re: A-body 8.75 with /6 [Re: slantzilla] #1161901
01/22/12 12:37 PM
01/22/12 12:37 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
10" drums were optional on pre '73 5 x 4" bolt pattern 7 1/4" rears.
Re: A-body 8.75 with /6 [Re: DoctorDiff] #1161902
01/22/12 03:05 PM
01/22/12 03:05 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
The A bodies around here usually never make it past the front gate at PullaPart with the 8 3/4's or disc brakes. There is a Mopar guy that snags them all.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: A-body 8.75 with /6 [Re: Rug_Trucker] #1161903
01/22/12 10:34 PM
01/22/12 10:34 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
My 71 Duster Twister has 10" drums and the 7.25 rear.
The local old time junkyard had (for years) a 70 Duster /6 3speed car with the 8.75 rear, but somebody took the axles and brakes a long time ago and everything was rusty as hell so nobody ever bought it.
I've been into A-bodies for 25+ years and sometimes it would surprise you to find 8.75 rears under cars that you wouldn't think would have them. I learned to look under EVERY car, cause you just never know.
